Old 01-30-2025, 07:31 PM   #1
Southcity
Southcity's Avatar
1966 K10 Suburban - dogdish modification
Wheels are 16" Vintiques smoothies which I've been running for over a year with no center caps. Recently got a set of 52 Chevy caps for these wheels from a friend. Performed some slice-and-dice to slip front caps over hub, painted rear caps. These were impossible to mount without making a small relief cut on the inner mounting ring to slide under the three mounting nubs on the wheel but here we are. This is temporary but used as mock-up to eventually mount a set of 50's Oldsmobile caps which I am in the process of modifying to fit.
66 GMC Suburban Custom
66 Chevy K10 Suburban
Southcity is offline   Reply With Quote
