Old 01-31-2025, 02:51 AM   #1
TyFullCircleFab
Lifting your 2wd
I’ve been reading a lot of posts of people asking about the early and next to impossible to find fabtech front suspension. We have taken that front suspension style and completely reengineered it to function correctly for everyday driving and even weekend fun on the trails or sand dunes. No lift spindles, and no need for uncomfortable 3/4 ton springs. This kit uses stock spindles with all new upper and lower control arms. It will lift the truck 1-4” depending on your coil over adjustment. As a big plus, it does not require any welding to install! You can run up to 35” tires without rubbing the frame at full turn too! You can head to fullcirclefabrications.com for more information or questions. Feel free to message me here too!
*Fits 63-87 Chevy trucks, Blazers and Suburbans*
TyFullCircleFab is offline   Reply With Quote
Old 01-31-2025, 11:38 PM   #2
IT Cowboy
IT Cowboy's Avatar
Re: Lifting your 2wd
Is this a bolt on kit?
IT Cowboy is offline   Reply With Quote
Old 02-01-2025, 02:00 AM   #3
TyFullCircleFab
This is a bolt on kit. But it does require trimming of the stock crossmember.
Old 02-10-2025, 08:27 AM   #4
IT Cowboy
IT Cowboy's Avatar
I have the highlander version and it looks like it is the heavy 1/2 ton with rear leaf springs. IDK if the front on these had heavier springs, would front couls from a C/k 20 work? The rear would be easy I think with shackles or axle spacers.
1972 C10 Custom Deluxe Highlander 402
Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility.
Old 02-10-2025, 11:56 AM   #5
TyFullCircleFab
Hi there Cowboy. You get rid of the coil springs in the front. This kit uses 2.5x8”fox or king coil over. And it works on c10 & c20 models.
Old 02-10-2025, 12:02 PM   #6
IT Cowboy
IT Cowboy's Avatar
Sorry, which kit and not link in your post - thank you
Old 02-10-2025, 02:27 PM   #7
TyFullCircleFab
The one kit fits all models. Unless it’s a C30. All the info and prices are at (www.fullcirclefabrications.com)
Old 03-01-2025, 05:32 AM   #8
TyFullCircleFab
Some testing out at KOH.
lift kit, lifted 2wd, lifted suburban, long travel, wide ride ifs
