![]() Join Date: Jan 2025
Which spark plugs and wires to buy?
I want to change out the spark plugs and wires so which set to get? I am thinking of the wire set with the ceramic boots on them to help with heat unless there is a reason against them or they are poor quality.
Oh also, is it ok to use anti-seize on the plugs?
1972 C10 Custom Deluxe Highlander 402 Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility. |
| Bookmarks |
