Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 02-04-2025, 05:58 PM   #1
IT Cowboy
Active Member
IT Cowboy's Avatar
Location: Clarkdale, Arizona in a van down by the river
Would coating inside the doors buy me some time ?
I have some paint issues on the truck and there is probably some rust inside so would taking the inside panels off the doors and coating the inside with rust preventative buy me some time or be worth the effort?
At some point the truck will need some rust mitigation and that might involve new panels and paint but I am hoping for quite a few years of fun and keeping it looking ok until I retire and can work on it all I want
'72 C10 / 402
___________________________________________
Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility.
IT Cowboy is offline   Reply With Quote
Old 02-05-2025, 09:02 AM   #2
raggedjim
raggedjim's Avatar
Re: Would coating inside the doors buy me some time ?
Some will say no, but I say if it's already rusty trying to slow it down isn't going to hurt and may even help.
I've had pretty good luck with Ospho (phosphoric acid) and then a moisture cure paint (POR-15, Chassis Saver, etc.)
Good luck, Rg
raggedjim is offline   Reply With Quote
