Old 02-05-2025, 12:12 AM   #1
IT Cowboy
IT Cowboy's Avatar
Is there a non-paper filter that goes onto the carb
I have a 402 with a 4 barrel carb and it has the fuel inlet line in the front side with a filter. Is there a non-paper filter for in there? I keep seeing them mentioned but I cannot find one on any parts lists or stores. Is there a small metal screen type, a lava stone type or how about an external in-line ne that threads into the carb . Or could I ditch the carb filter and just use a filter somewhere between the tank and carb
1972 C10 Custom Deluxe Highlander 402
Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility.
IT Cowboy is offline   Reply With Quote
