Old 01-15-2004, 08:26 PM   #1
cochino12
It followed me home?
cochino12's Avatar
4sp to th350 ?
how difficult of a swap is this? on an '83 2wd. Other than obvious stuff whats needed? would I need a new drive shaft? Thanks for any info
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 01-16-2004, 12:40 AM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
youre gonna need the proper flexplate the tranny torque converter tranny lines tranny etc. youll also need the cross member i think the automatic driveshaft is shorter you may need a different yoke.you can prolly find one in the junkyard.
if you decide to do ths swap i can use some of your clutch pieces specifically the cluthc pedal assy and the linkages to the frame and the rubber grommets
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 01-16-2004, 11:04 PM   #3
mike reeh
5 day ban, learn to behave.
mike reeh's Avatar
how do you plan on shifting gears? Unless you go with an aftermarket floor shifter, you will need a new steering column and related linkage & bracket
mike
mike reeh is offline   Reply With Quote
Old 01-23-2004, 01:20 AM   #4
mcmlxix
Collector of Projects
mcmlxix's Avatar
How long is a SWB drive shaft from center of U-joint to center of U-joint from an automatic ?
Rich
1972 K5 Blazer CST Click HERE
