Old 02-09-2025, 04:06 PM   #1
Don D
Junior Member
GM Automatic Tilt Steering Column Shortened 2”
GM Automatic Tilt Steering Column Shortened 2” for 67-72 Chevy trucks. Column has been shortened to give more room between the steering wheel & the seat, moves the steering wheel 2” closer to the dash. So if you are a big guy it gives you some more room. The column was stripped down & checked for worn & broken parts & replaced if needed. Column was painted back black and reassembled using the following new parts. Turn signal switch & wiring harness with correct curved wire connector, correct hazard light knob, ( not the red one ), neutral safety switch, lower bearing, lower bearing retainer, upper & lower rubber seals, inside tube seal, shift indicator pointer, shift indicator lense, shift lever, turn signal lever, tilt lever, & shift arm rubber grommet. Also includes cancel cam/horn contact & spring. It is ready to bolt in & go with no modifications.
$700.00 Plus Shipping/ Shipping to U.S. Only.
Don D is offline   Reply With Quote
Old 02-09-2025, 04:08 PM   #2
Don D
Junior Member
Originally Posted by Don D View Post
GM Automatic Tilt Steering Column Shortened 2” for 67-72 Chevy trucks. Column has been shortened to give more room between the steering wheel & the seat, moves the steering wheel 2” closer to the dash. So if you are a big guy it gives you some more room. The column was stripped down & checked for worn & broken parts & replaced if needed. Column was was painted back black and reassembled using the following new parts. Turn signal switch & wiring harness with correct curved wire connector, correct hazard light knob, ( not the red one ), neutral safety switch, lower bearing, lower bearing retainer, upper & lower rubber seals, inside tube seal, shift indicator pointer, shift indicator lense, shift lever, turn signal lever, tilt lever, & shift arm rubber grommet. Also includes cancel cam/horn contact & spring. It is ready to bolt in & go with no modifications.
