Squeak or whistle inside when starting or shutting down
It is coming from in side and it makes a distinct whistle type squeak in the same pattern. I think it is from the HVAC system and possibly the blend door closing, It is not a belt and it does it on startup and on shutdown
1972 C10 Custom Deluxe Highlander 402
Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility.
