Old 01-15-2004, 08:52 PM   #1
Bryan H
Bryan H's Avatar
Question Question About Power Steering Gear Boxes
I'm wanting to put power steering on a 68 GMC that did'nt come with it originally and my frame is not notched out for the gear box like a frame with power steering. I'm wondering can I use a box from a different year and not modify the frame or will I have to modify my frame to make any power steering gear box work? Thanks for the reply.
Bryan
1980 Malibu Classic 2 dr coupe
1964 Impala SS 4 speed
1968 GMC (major project) grandpa bought new
1969 Chevrolet C-10 Shortbed Fleetside
2008 GMC Canyon (daily driver)
Bryan H is offline   Reply With Quote
Old 01-15-2004, 10:20 PM   #2
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Your frame should be indented, they are not notched. I haven't ever seen a 68 that wasn't. WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 01-16-2004, 12:19 AM   #3
Bryan H
Bryan H's Avatar
My frame is not indented for a power steering gearbox. I went to the junkyard today and found one that had power steering and my frame is different. Mine is straight along the outside edge of the frame where the p/s frame had the indention. Both trucks are 2 wd. Wes I noticed on your web page you modified your frame on your panel for the same reason. Was that for that particular gearbox you used or because you was changing it to power steering?
Old 01-16-2004, 01:13 AM   #4
toms68cst
toms68cst's Avatar
I've heard of a few folks with unindended 68 frames. The earlier style ram power steering was offered on the 68's. I wonder if they didn't make the transition to gear box PS later in the year. My 68 (Manufactured around summer '68?) had the indents when I put one on a few years back.
P.S. You will have to put a small notch in your front D.S. bumper bracket though.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles.
TREASURER, Drum Brake Club.
toms68cst is offline   Reply With Quote
Old 01-16-2004, 01:49 AM   #5
Pont
I need another Barley Pop
Pont's Avatar
To the best of my knowledge, early 68's did not have the indent and late 68's did. I know for a fact my 67 was not indented and I'm using a p/s box off of a 77. Instead of modifying the frame, I simply built 1/2" spacers to stand the box away from the frame for each bolt. I have been running this setup for 2 years next month without any problems.
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
34 Ford 2 door sedan - Long term project
There is a very fine line between "hobby" and "mental illness"
Pont is offline   Reply With Quote
Old 01-16-2004, 03:48 PM   #6
Kenneth Brown
I had a 66 and we used pipe for spacers also. The bump steer was off because I didn't spend enough time getting everything perfect but it will work.
Kenneth Brown is offline   Reply With Quote
Old 01-16-2004, 04:36 PM   #7
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
On my 67 it does not have a indention. I just notched it out.
67Fleetsidedream is offline   Reply With Quote
Old 01-16-2004, 05:30 PM   #8
Erl
Erl's Avatar
1967 and early 68 4x4 models did not have an indentation in the frame. I will be adding P/S to my truck in the near future. I plan to indent the frame. Adding shims without indenting the frame will cause a misalignment. This might not be a problem, but it would be better to be properly aligned. GMCPaul sells a spacer kit.
Erl
1968 GMC 305 V6 3/4 4x4 Stepside
06 Corvette Daily Driver
Dallas TX
Erl is offline   Reply With Quote
Old 01-16-2004, 08:40 PM   #9
charles oliver
68 camtruck
charles oliver's Avatar
68 power steering conversion
I just last year converted a 68 C10 from standard to power steering. I didn't have a problem with the gearbox but did have to get a draglink (Centerlink) as some say, also the rag joint. Everything came from a 71 donor truck. Once you convert it you will be glad you did.
Charlie
71 GMC Jimmy 4X4
68 Huger Orange Camaro 454 with TH400 :gmc
charles oliver is offline   Reply With Quote
Old 01-16-2004, 11:20 PM   #10
Bryan H
Bryan H's Avatar
Thanks for all the replys. I'll probably just use spacer then becaused I've already painted my frame with POR 15.
