Active Member
![]() Join Date: Jan 2025
Location: Clarkdale, Arizona in a van down by the river
Any way to verify a SPID sheet or ID a fake
I am sure there are probably some fakes out there but it there any way to verify a truck and its options? Many options were coded in the VIN but I imagine the re-sellers, flippers or rebuilders could make more money off misrepresenting a truck or just the persons trying to make a clone.
Certain things on my truck line up with what the SPID says but others seem wonky. I do not know enough yet to determine what but I suspect that either 1 -Someone slightly changed the truck and then someone else started putting the truck back to the factory original, but they never finished, and then another person added their flare to it. 2-Someone took my truck and tried to make it something it never was or made it a franken truck. It was repainted and they scribbled the build codes on the firewall The best I can tell is the only things no factory about my truck are aftermarket rally wheels added 2nd fuel tank removed dual exhaust added door protection molding removed aftermarket air cleaner highlander seat was replaced with a solid-color bench repainted like a factory paint job charcoal canister removed I really don't care as it is a nice truck and I will enjoy it but it would be nice if there were factory records to verify it. I am sure an expert could point out a lot more things too. I am torn between trying to return it to factory's original. The thing is I like some of the mods and would probably never be able to get it original enough to pass muster at a car show for looking original. I wont fret about it but I would love to know the true history of it and where it has been and what it has seen.
'72 C10 / 402 ___________________________________________ Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility. Last edited by IT Cowboy; Yesterday at 10:06 AM. |
Roadtrip!
![]() Join Date: Feb 2003
Re: Any way to verify a SPID sheet or ID a fake
Your SPID looks authentic to me.
It was common to have chalk markings on the firewall. Rally wheels came out after 72. Dual exhaust may be factory with a big block. That is a nice truck, you should just go out and enjoy it.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Who Changed This?
![]() Join Date: Jan 2013
Yes, big blocks got dual exhaust. As for the vapor canister, it might behoove you to reinstall that. Either gas cap is going to put some sort of pressure on the system, unless the vapor line is securely closed off. That may already be the case, if you aren't smelling fumes.
#4 | |
Active Member
'72 C10 / 402 ___________________________________________ Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility. |
