![]() Join Date: Aug 2007
Early 70's 16" x 7" and 6.5" Wide 8 Lug 4 knub Steel Wheels / 3/4 ton disc set-up -
Early 70's 16" Dia x 7" and 6.5" Wide 8 Lug 4 knub Steel Wheels / 3/4 ton disc set-up
-fit 3/4 ton with front disc brake set-up or drum brakes -(1) set of (4) 7" wide or (1) set of (4) 6.5" wide -4 knubs on wheel for use with hub caps -need sandblast and paint or use as rollers -tires have been removed $100 each set / pickup only zip 48092 Warren, MI ALSO have only (1) 16" Dia x 10" wide 8 lug steel wheel / $35 Last edited by jimmy70; 02-10-2025 at 06:27 PM. |
Re: Early 70's 16" x 7" and 6.5" Wide 8 Lug 4 knub Steel Wheels / 3/4 ton disc set-up
ttt
ttt / I can send pix if requested
| Bookmarks |
