Old Today, 04:35 PM   #1
GOPAPA
GOPAPA's Avatar
Question about speaker bracket location bolt up
I have run wiring both sides behind the seat in my truck to the corners ,,and want to know if any of you have used the corner (speaker brackets) for 6 x 9 speakers ?
If so how does the brackets connect to what ever they are suposed to in the corners..My corners are wide open and built that way from factory with no screw holes for the speaker brackets .
I put in a better search word and found what I think I need to know about my question ,,if anyone has advice please feel share
When you learn a thing a day you store up smart.
GOPAPA is offline   Reply With Quote
Old Today, 04:55 PM   #2
Willie Makeit
Willie Makeit's Avatar
Re: Question about speaker bracket location bolt up
i've used the brackets offered over on the Parts page multiple times both in 67-72 trucks as well as squarebody trucks, held in place with 2 sheet metal screws.
Willie Makeit is offline   Reply With Quote
Old Today, 06:02 PM   #3
GOPAPA
GOPAPA's Avatar
I have brackets coming for $20 and they are described to fit 1973-87 C-10 looks like no preholes drilled for mounting ,,but of course that can be done .
Thanks for replying
Old Today, 06:26 PM   #4
Dead Parrot
I had to drill holes for the OEM brackets that fit 4x10s.
Double check fitment of the speaker magnets before drilling. Aftermarket magnets tend to be larger then the OEM magnets. Be prepared to either adjust metal via a hammer or use spacing washers.
Dead Parrot is offline   Reply With Quote
