Old 02-11-2025, 08:17 PM   #1
ihv800
Help figuring out miss in an HEI 350?
Hello!
Working on an '82 GMC for a friend trying to get it tuned up and running nice. It was brought to me with a no start condition, an HEI module fixed that up. I used an NOS US made Echlin.
I've got a miss I cannot figure out, though. Cylinders 8 and 5. 8 seems to not be contributing at all. With no load 5 is dead, if you let it load up against the converter pulling the wire on and off 5 does make a detectable difference but it's a weak contribution.
Compression on 5 and 8 is around 130 as are other cylinders that are working fine. Valves are goin up and down so the cam isn't flat, and I have checked and readjusted the rocker arms. I've tried swapping plugs and wires around with good cylinders and the problem persists. I've tried new plugs and wires with no change. I've reclocked the distributor and moved the wires over one post on the cap, 5 and 8 still do the same thing. The spark will jump all over from the cap when you pull those wires off and have good spark at the plug.
I must be missing something but I've tried everything I can think of? I thought the pickup was doing something wonky, but figured reclocking the distributor would move the issue and it didn't. I don't see any ignition issues and it makes effortless compression when testing those cylinders. It is interesting to me that the problem cylinders are 180 apart. Before I pull the rest of my hair out I thought I'd put around the table for ideas.
Thanks!
ihv800 is offline   Reply With Quote
Old 02-11-2025, 10:48 PM   #2
eric8
Re: Help figuring out miss in an HEI 350?
Well take this story for what it’s worth, I had a no start condition as well that came out of nowhere with an HEI. It made me pull my hair out too. I replaced the module with a U.S. made Standard Motor Company module (apparently the same as Echlin). That immediately fixed the no start condition, but when I revved over 2k rpms it would miss and backfire like crazy.
Sent that module back and ordered the following kit from Proform. They make the distributors that come in the GM performance crate motors. Not shown in the picture, but the kit also came with an assortment springs, and the GM “ZZ series” crate motor center cam and weights. A weak coil can show up good when you ohm it out but cause all kinds of problems frying modules and making them do wonky things. This kit basically replaces everything in the equation except for the pickup coil. Whatever was wrong, it fixed all my issues. Also make sure your distributor has a good ground through a bare distributor hold down clamp to the block. Look for any obvious signs of chafing or wire breakage on the wires going to the pickup coil. The movement of the vacuum advance mechanism back and forth can weaken the wires and cause intermittent connections. Ensure a full 12v at the HEI wire that plugs in to the cap just to rule out a voltage drop.
eric8 is offline   Reply With Quote
Old 02-11-2025, 11:01 PM   #3
eric8
An additional note, Proform makes the exact kit above under their own name that they said is identical (minus the GM Performance badging), which saves you a little money. $86 for this kit. Really a lot for your money considering what you get, including a new coil, brass terminal cap and rotor, rotor bushing/button, module, new module to cap harness, tunable vac advance and and springs to dial in a nice mechanical advance curve. The weights and springs will let you dial in your all in advance by 3k rpm’s and have a much better curve. Came with a chart that shows what the different combinations of springs will get you.
Old 02-11-2025, 11:53 PM   #4
Dead Parrot
Vacuum leak in the plumbing related to the aft intake vacuum port. IIRC - that feeds to both 5 and 8. Too much air, lean mix -> misfires. Also check the brake booster. Those can leak and still provide some boost.
Dead Parrot is offline   Reply With Quote
Old 02-12-2025, 01:55 AM   #5
ihv800
Thanks for the thoughts, Eric. I *think* the ignition components are working properly. It runs strong at all RPM's minus the miss and seems to have strong spark even on the problem cylinders. Definitely need to check out a few things there, the module wiring warrants a closer look, as does ensuring good grounds and voltage to the coil. Though it doesn't mean it's not the problem, I trust that old Echlin module more than anything you can buy today. I might toss another module in if I don't find anything else. I do question the pickup coil. Cap and rotor have obviously been recently replaced, nice units with brass contacts.
You really might be onto something there... It runs and idles great outside the miss, but it is definitely lean. I figured carb issues but wanted to sort out the miss first. I was fixated on ignition and mechanical issues I didn't give much thought to vacuum leaks. I know exactly what port you mean, and it would primarily affect #8 then slightly less #5. Great suggestion, I will give that a look.
Old 02-12-2025, 07:47 AM   #6
eric8
Just out of curiosity, when it was brought to you with the no start condition, what were the circumstances surrounding it? Was this a "barn find" truck that had been sitting for a long time? Or a daily driver for your friend where the no start just appeared out of nowhere? Please keep us posted as I like to know the outcome of stuff like this.
Old 02-12-2025, 06:35 PM   #7
ihv800
Dead Parrot, you get the gold star and can send me a bill whenever! That aft vacuum port was the problem. It was plumbed to the Hydramatic modulator and then had an uncapped open T. Plugged that up and 8 & 5 came alive. I've seen a lot of vacuum leaks cause all sorts of issues but never one act quite like that. Thanks for the suggestion.
As said, an open fitting on that manifold vacuum port between the carb and distributor in the #8 runner was the issue. Buddy bought it cheapish on Craigslist. Previous owner said it had been running recently. He claimed the no start happened the day my buddy went to get it. It's not been on the road for a while but has obviously been running recently so that seems about right.
Old 02-12-2025, 11:52 PM   #8
eric8
Good to hear you figured it out. Good catch Dead Parrot!
Old 02-13-2025, 10:05 AM   #9
Dead Parrot
Glad that fixed it. Possible that leak is why it was offered cheap on CL. Rough running motors tend to lower prices. Also likely it had a trans shifting issue due to the vacuum modulator getting a bad signal. Also possible the seller was frustrated by the AC vent controls not working. Those are vacuum operated and often connected at that aft port.
Old 02-17-2025, 05:52 PM   #10
cadillac_al
I was diagnosing a miss on my K20 and it seemed to be on both sides of the engine with the same rhythm. I have a very free flowing exhaust so it is very easy to hear the misfires on either side of the truck. I was thinking it could be my 20 year old Accel spark plug wires so I ordered a tune up kit from rockauto and was waiting for it to be delivered.
After reading this thread I thought I would check that rear vacuum tap to see if anything could be leaking. Everything was fine and only my trans is plugged in there and the hose was not cracked. While I was there I unplugged my vacuum advance to verify that it was still working. When I unplugged it my misfire completely disappeared. I couldn't believe it. I plugged it back in and the miss came back. I did this about 3 times. While I was playing I put the vacuum gauge on it and this engine runs so sweet it pulls 21 inches of vac with or without the vacuum advance. I now put the vac advance on ported vacuum and the truck appears to be very happy.
This will be the first engine I have ever had that did not like full manifold vacuum to the vacuum advance. Maybe, just maybe, my ignition is still weak and can't handle that much advance at idle. My vacuum advance can is for a truck and only advances about 10 degrees so the vacuum advance isn't excessive. I just thought I would add this here in case somebody else is trying to diagnose a miss and it isn't a vacuum leak at the rear manifold vacuum port. Try unplugging the vacuum advance for the fun of it and see what happens.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
