Old Today, 01:39 PM   #1
IT Cowboy
Active Member
IT Cowboy's Avatar
Location: Clarkdale, Arizona in a van down by the river
Can the TH400 solenoid be replaced without removing the pan?
I think the single wire solenoid on my trans is weeping a bit or is the source of a lot of the oil residue on the bottom of the pan and can that be replaced without removing the pan? I was hoping it is a matter of popping the old one out and shoving a new one in with an o-ring or gasket? I did put some dye in my trans fluid to try to verify the leak.
'72 C10 / 402
___________________________________________
Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility.
IT Cowboy is online now   Reply With Quote
Old Today, 01:51 PM   #2
kwmech
Re: Can the TH400 solenoid be replaced without removing the pan?
Sorry no, it pushes from the inside out
Old Today, 02:02 PM   #3
IT Cowboy
Active Member
IT Cowboy's Avatar
Damn, someone should make an adaptor to be able to put in and then thread one on. I kinda want to have a drain plug in the pan so maybe I will tackle the job.
'72 C10 / 402
