Old Yesterday, 05:16 PM   #1
IT Cowboy
Active Member
IT Cowboy's Avatar
Location: Clarkdale, Arizona in a van down by the river
Will the TH400 auto do a burnout?
I think mine is meant for torque and hauling like a farm truck meant for work and not for speed. Would it take a new torque converter, stall converter, or different gearing?
'72 C10 / 402
___________________________________________
Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility.
IT Cowboy is offline   Reply With Quote
Old Yesterday, 05:40 PM   #2
Tom
driving is in my blood
Tom's Avatar
Re: Will the TH400 auto do a burnout?
A trans is a trans, it doesn't dictate power output of the engine.
Any transmission will do a burnout with a strong enough engine in front of it.
Yes, you can change the stall by replacing the convertor.
Old Yesterday, 05:54 PM   #3
IT Cowboy
Active Member
IT Cowboy's Avatar
I have the 402 so I might be able to power brake it right now. I was just curious more than anything as I dont need to stress it anywhere and break anything
'72 C10 / 402
Old Yesterday, 06:00 PM   #4
AcampoDave
AcampoDave's Avatar
Most old empty V/8 pickups I've seen can do pretty good burnouts. Provided the engine is in tune. Smaller wheel diameter (like 15" rims) helps too.
AcampoDave is offline   Reply With Quote
