Old Yesterday, 08:26 PM   #1
Don D
Junior Member
GM Floor Shift Tilt Steering Column Shortened 2”
GM floor shift tilt steering column for 67-72 Chevy Trucks. Column was originally a automatic column that has been converted to a floor shift column. It has been shortened 2” to give more room between the seat & steering wheel, moving the steering wheel 2” closer to the dash. Column was stripped down & checked for worn or broken parts & replaced if needed. Column was painted black & reassembled using the following new parts. Turn signal switch & wiring harness with the correct curved wire connector, hazard light knob, upper & lower rubber seals column tube seal, lower bearing, lower bearing retainer, turn signal lever & tilt lever.
$650.00 / Plus Shipping / Shipping to the U.S. only.
Don D is offline   Reply With Quote
