Old 02-12-2025, 09:22 PM   #1
michael bustamante
michael bustamante's Avatar
Window crank handle repair....need advice
So I got a couple of nice 67 inside window crank handles a I'm the knobs are missing
Anyone know how to put a new or a good used knob in and where to get the knobs only so I could use these handles?.
I did a search but I didn't find anythnng
1967custom
michael bustamante is offline   Reply With Quote
Old 02-12-2025, 10:12 PM   #2
custom10nut
custom10nut's Avatar
Re: Window crank handle repair....need advice
You may have to go on the hunt for some good original factory handles at swap meets.
I don’t know if any vendor that just has the knobs.
custom10nut is offline   Reply With Quote
Old 02-12-2025, 10:58 PM   #3
cericd
cericd's Avatar
Dorman makes a product, part number 76905 that appears to be pretty good copy of the stock knobs. It comes with the knob, a "rivet" and a washer. Should be available in yhe HELP section of your local auto parts store. I've never use them but may be worth a shot. Maybe someone else has used them and can chime in.
These are old pics but show what's included and the instructions. Obviously they've been making these for a while now.
Chris
My 1970 SWB C/10 - https://67-72chevytrucks.com/vboard/...d.php?t=534872
cericd is offline   Reply With Quote
Old 02-13-2025, 12:29 AM   #4
dmjlambert
dmjlambert's Avatar
I don't know if the knobs are one of the 67-one-year-only items. If they are like 68-72 then the knobs can be obtained from the car parts stores in clear and black. I believe I got mine at Napa. Here is a recent discussion. https://67-72chevytrucks.com/vboard/...d.php?t=856396
dmjlambert is offline   Reply With Quote
Old 02-13-2025, 01:00 AM   #5
cericd
cericd's Avatar
Yep, those look to be the same as the Dorman ones I was referring to. I posted pics of the old packaging because the Napa and Oreilly sites don't show the hardware for attaching the knob. Napa is even using the same exact images as the Oreilly site for the Dormans shown here. Any issues installing them? Do the feel like they'll hold up with regular use?
Chris
Old 02-13-2025, 02:24 AM   #6
pjmoreland
pjmoreland's Avatar
https://classicparts.com/1967-76-ins...dle-knob-black
pjmoreland is offline   Reply With Quote
Old 02-13-2025, 03:57 AM   #7
'68OrangeSunshine
'68OrangeSunshine's Avatar
I have used the Dorman Repop knobs. They work OK, for a while, but can come loose.
The best method of setting the rivet in the knob is to put it in a vise and slowly compress the knob onto the rivet thru the handle. Whacking it on with a ball-peen hammer can lead to misalignment or mishaps.
Over torqueing can cause the knob to be too stiff, and not roll freely.
Dorman also used to sell the full handles, w/knob attached. Don't try them -- they suck, and can be too brittle, breaking off in your hand. Better a real GM handle to work with.
Old 02-13-2025, 10:36 AM   #8
cj847
cj847's Avatar
a new complete handle is only $5-8 depending on where you get it.
https://classicparts.com/chevy-gmc/t...ith-black-knob
cj847 is offline   Reply With Quote
Old 02-13-2025, 12:07 PM   #9
cericd
cericd's Avatar
The OP is talking about '67 window cranks. They were a one year only design that looked a bit different and matched the '67 door handle levers. I don't believe the '67 cranks are repopped. Also, many people say that the repop cranks don't properly fit the splines of OEM window regulators and prefer a good used, or NOS set of originals.
These are '67 only cranks and handles.
Chris
Old 02-13-2025, 12:35 PM   #10
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: Window crank handle repair....need advice
https://www.ecklers.com/ca-corvette-...RoCitIQAvD_BwE
https://www.classicindustries.com/pr...RoCwF4QAvD_BwE
Old 02-13-2025, 06:35 PM   #11
'68OrangeSunshine
I have had a '67 K/10 Suburban and I remember the unique slimmer '67-only design. I have run the '68 style Door Handles and Window Cranks -- they fit the splines fine, as I recall. I don't remember if the round knobs were the same. Thought so. Not sure.
The later models are stouter, and won't break as easily. But not period correct.
