![]() Join Date: Jul 2003
Added full gauges to 79 Chevy truck
Other than changing the instrument cluster, what else needs to be changed on a 79 Chevy truck to go from idiot lights to full instruments? The truck is a 6 cylinder, 3 speed on the column.
Thanks Doug |
Professional Grade
Senders, and maybe the wiring harness, not too sure though.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
You get what you pay for
![]() Join Date: Dec 1999
When I changed a van over from lights to gauges, I had to change the senders. The plugs on the harness are the same and will plug up to the light harness. The wiring is the same color, but the wires are in different locations in the plug. What I did was to make sure you get the plug from the donor truck. Then cut your old one off and wire the new one color to color.
Worked for me.
Mike 1985 Chevy C-10 |
Professional Grade
Ah, knew there was some rewiring to do
![]() Thanks Mike
