Old 02-14-2025, 09:11 PM   #1
IT Cowboy
IT Cowboy's Avatar
Is there way to modernize the key switch?
Last evening my battery died and I think what happened is that I had turned the key to acc. and removed it. My key worn to where it almost looks like a blank. Is there a newer switch that would have a more positive click or engagement in each position?
I put in a new battery this afternoon and the other one was 4 years old and its condition was not known. I tested the new battery and it was drawling .02 with the meter between the neg and then .17 while connected to the truck with both leads.
1972 C10 Custom Deluxe Highlander 402
Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility.
IT Cowboy is offline   Reply With Quote
