Old 02-15-2025, 04:43 PM   #1
jhe.1973
jhe.1973's Avatar
1986 K20 Steering box to 1969 C30 frame
Hi Everyone,
Will a power steering box from a 1986 4WD K20 fit a 69 C30? I.E. will the pitman arm fit the splines of the box?
Thanks much for any help provided!!
Best wishes to ya’ll. Sincerely, Jim
"To invent you need a good imagination and a pile of junk" - Thomas Edison
"I've always wanted to get a job as a procrastinator - but, I keep putting off looking for one - I guess I'll never realize my life's dream - so sad." - Me
My C30 wrecker build/repair/update thread: https://67-72chevytrucks.com/vboard/...d.php?t=855904
jhe.1973 is offline   Reply With Quote
Old 02-15-2025, 04:59 PM   #2
jerry moss
Born Psycho
jerry moss's Avatar
Re: 1986 K20 Steering box to 1969 C30 frame
it will bolt up to the frame but 4x4 pitman and 2wd pitman are totally different
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 02-16-2025, 02:16 AM   #3
jhe.1973
jhe.1973's Avatar
Thanks Jerry for responding!
If I had looked closer before I posted this question I would have seen that the later steering box shaft doesn't have the same style tapered, splined shaft as the earlier box.
The pitman arm isn't held on with an end nut.
Instead it uses a through bolt which clamps the arm to the shaft. My guess is that the shaft has a curved notch to accept the bolt and keep it from being able to slide off.
Old 02-16-2025, 11:14 AM   #4
57taskforce
All about them K’s
57taskforce's Avatar
The direction that the pitman moves is completely different between the two as well. C30 will move side to side and the K20 is forward and back.
Tyler
57taskforce is online now   Reply With Quote
