Old 02-19-2025, 09:46 PM   #1
G-749
Active Member
292 fuel pump ?
Hello all,
What are all you folks with 292 using for fuel pump replacement for 71 292 with Rochester
Monojet ? Which one to buy , which one not to buy . Got really lucky today , fuel pump quit before truck got warmed up enough to drive to town . Thanks in advance.
Good luck on all your projects!!!
G-749 is offline   Reply With Quote
Old 02-20-2025, 01:05 AM   #2
geezer#99
geezer#99's Avatar
Re: 292 fuel pump ?
I betcha it wasn’t the fuel pump!
Likely the weather.
Do you have an operating choke and heat riser on the exhaust.
Old 02-20-2025, 01:55 AM   #3
franken
Re: 292 fuel pump ?
I'd go to the local parts store web site and find the pump there. Then buy it locally.
franken is offline   Reply With Quote
Old 02-20-2025, 12:05 PM   #4
G-749
Active Member
Re: 292 fuel pump ?
Not the weather, put Pertronix ll ignition and coil 2 weeks ago , choke and heat riser still in place and working, clear fuel filter dry ,no gas in it . When I cranked it up yesterday using the choke ,wouldn't run unless choke was fully on ,1st clue something was wrong , truck last few times I drove it had "flat spot" about 55 mph and wouldn't go any faster , checked timing, idle speed , vacuum, fuel filter had gas in it on Monday. Hope it is fuel pump and not Crusty Rusty in fuel tank !!! Original truck w 68,889 miles on it , have put 1200 + miles on it since I got it .
Thanks to all who replied.
Old 02-20-2025, 04:13 PM   #5
RichardJ
Re: 292 fuel pump ?
Doesn't really sound like fuel pump.
New Pertronix and it runs like crap does not surprise me.
Recent experience with new pump. Bought one from O'reilly listed as "Precision Pump". Checked running pressure with "T" fitting at 12psi. Was supposed to be 5.5-8 psi. Took it back and got another from them called a "Delphi Pump". It was supposed to be 7 psi, but produced 14 psi.
Summit sells a "Carter" pump, but they don't give the pressure. Carter web page says this pump provides a min. of 3 psi and a max of 5.5 psi. Installed this one and produced 14 psi.
The Carter pump box contained a baggie with a part # on it, with a gasket and inst sheet inside.
The Delphi box contained the same baggie, part # and inst sheet. Both pumps appeared to be exactly the same and the Precision Pump was probably identical.
I called Carter and got the typical bla, bla, bla. It took some gumming before he finally admited they were the same pump, but remained vague about which one or if even someone else made both.
He said Carter was fully aware of the overpressure problem with mechanical pumps and was in the process of redesigning all their pumps.
Yada, yada, yada.
With the pumps sold today, you need a regulator. I wouldn't trust one of those MrGasket/ JCWhitney regulators. I got a Holley style regulator from Jegs for $20.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 02-20-2025, 10:21 PM   #6
G-749
Active Member
Re: 292 fuel pump ?
Awesome ,this is exactly the type of information that I was looking for ! The picture really rocks , made my day . I can see the need for the regulator. I have a pressure gage and will definitely use it . The 71 Chevrolet Truck Chassis Service Manual that I have says 3-5 lbs for
the pressure for my application. Guess the old Rochester Monojet with manual choke will need external regulator before i blow it up with a new fuel pump . Carb and fuel pump appears to be original equipment on this 292 . Truck is a 71 C 50 292 4 sp with vacuum operated 2 sp rear end . Thank you so much for your time and consideration and pictures. Vacuum holds steady at 17.5 , truck has a gigantic vacuum booster underneath the cab and vacuum control unit to shift rear end . If you have any more wisdom and knowledge to share about this don't hesitate to add to replies. Thanks man , have a great day!!!
Old 02-21-2025, 02:37 AM   #7
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: 292 fuel pump ?
I've been running an Edelbrock 1404 [500 CFM] 4 barrel carb on an Offenhauser intake on my 292 L6 with a stock mechanical fuel pump for 20 years and I've never had the alleged fuel feed overpressure gripe everyone's chasing here.
Eddies are alleged to have fuel pressure sensativity.
I did bow to popular internet sentiment once and put a Holley Fuel Regulator on the Carter AFB 9635S feeding my V8 350 on a '71 GMC Jimmy many years ago. When I hired an expert to help me tune up my 350 so it would pass emissions, he looked at the Regulator and said you don't need that. So I took it off.
The gripe was in the chinese parts in my HEI.
On my 292, I did run a Pertronix Ignitor II/Flamethrower II coil on an Accel Blueprint L6 distributor. It ran well for about 7 years, then I experienced the following gripe:
Started and ran fine at street speeds ~55MPH.
At RPMs above 3000 [just when the Ignitor II was supposed to do its thing] the Ignition would black out. I'd be deadmilling -- whole rotating assembly moving at speed without spark -- until I switched Ignition OFF, then ON, then popped the clutch in 4th or 3rd. It happened whenever I tried the Freeway.
I discussed this with the Pertronix tech on the phone who said to send in the components and they'd check it out.
I never heard back.
I went back to points for a year, then converted to a US made HEI.
No further ignition problems in 9 years.
Old 02-21-2025, 10:43 AM   #8
G-749
Active Member
Re: 292 fuel pump ?
Thanks for reply ,
On the Pertronix thing, I put that in 2 weeks ago because of the "I can't drive 55" , old Sammy Hagar song . Changed points , condenser, rotor button, distributor cap ,wires, plugs , multiple ignition timing resets ,going up and down timing advance changes , idle rpm , vacuum gage, motor still "flat" about 45 mph . New 190 degree thermostat, new Northern radiator, New 22.5 rim$ n Goodyear tire$ . Tried the Pertronix thing cause I had 200.00 credit at Classic Industries. The only way I can set timing and idle is drive to town and run the old girl hard on the way home , 10 miles , to get the temp gage to move to warm, 2 lines on the gage. Guess I need to put a tach in it to see what going on. In lo range rear end can wind motor up, in hi range 50 mph max before "flat" . Got new Remflex gasket to fix leak between in take n exhaust manifolds, will adjust rocker arms when I do the gasket next week . I am open to any and all suggestions on how to get a little more out of my 292 . The "flat" spot really bugs me . Thanks to all who have replied . Good luck on all your projects!!!
Old 02-21-2025, 12:55 PM   #9
RichardJ
Re: 292 fuel pump ?
>>last few times I drove it had "flat spot" about 55 mph and wouldn't go any faster<<
Could you take another stab at describing this flat spot?
A C50 with a 2 sp rear is going to have rear gears as described below by CarolinaHD 4 years ago. I don't know how to do Quote from an old thread.
My 3/4 ton with 292, had 4.56 gears from new and freeway driving was a challenge. It could do 65 (screaming), but it was happier at 55.
I installed 3.54 gears in the Dana and with 285/70R17 tires it will now cruise at 75 all day, without complaint.
My truck has been on the scales @4600# empty. I have no idea what a C50 weights, but I'd guess north of 6000#.
Like '68 Orange, Mine has a few mods. Carter AVS 4bbl, Clifford intake, headers, 9:1 LPG pistons, larger valves and mild cam.
Power isn't the problem with a 292 even in stock trim, it just doesn't like the rpm those gears need for highway speeds.
>>I did bow to popular internet sentiment once and put a Holley Fuel Regulator<<
I didn't bow to anything. I checked the pressure and while the engine ran fine, I'm not going to take the chance that the 14 psi won't damage the needle/seat in the long term.
Old 02-21-2025, 04:14 PM   #10
G-749
Active Member
Re: 292 fuel pump ?
Thanks for reply and interest,
1971 C 50. 292 w 4sp and vacuum operated 2 sp rear end End, 8 x12 ft flatbed
SPID missing off glove box door gear ratio option I'm guessing only 3 available that year excluding diesel 6.5 -8.85
Haven't put truck on scale. Other FB C series groups put weight at 10k +
Truck runs 30 mph in lo range, 4th gear and is screaming
Truck runs to 45 + in high range 4th gear,between 45 mph and 55- mph , runs out of gas/ power, if you feather the gas pedal you can get to almost 55mph if coasting down hill, motor is not screaming like when you are using lo range, i use oil pressure gage for motor rpm ,lorange puts oil pressure 1 mark from H in gage, in hi range oil pressure gage only goes to halfway mark, you would have to be there, to see this.
Almost like a governor??? but I know no governor on truck ,maybe safety feature to keep idiot driving from going too fast!
Will ,keep working on this.
Thanks to all!!!
Old 02-21-2025, 05:44 PM   #11
'68OrangeSunshine
Re: 292 fuel pump ?
Yeah, a C/50 is a whole different beast. My C/10 Stepside was a fleet runner. Possibly CalTrans surplus by the 516 Orange paintjob. Original buyer specified L25 292, M20 [SM465] and 17.5x5.25'' rims with 7.00x17.5 6-ply bias tires. Original diff was 3.73 I think. [Not SPID specified.]
It glided very well until 4/2022 when I got T-Boned Downtown.
Now I may have frame issues.
My 292 is the original engine block, but has been rebuilt [Ca.2005] with .030-over pistons, 8:1 compression , 1.84 Intake valves, Clifford headers, Offy intake, Edel 1404 4-BBL Carb, HEI. SM465, 12-Bolt Corp rear @3.73. Don't have Posi right now. I had it removed from my T-Boned rearend and will get it reinstalled after I straighten out the frame or steering situation. Bought it used in June 1973.
On those few occasions, I've driven a rental or studio box truck with the split axle shift, the driver had to pull the shift splitter on the stick at the right time. A trick I never quite got, since it wasn't my daily driver.
A couple of years ago, when my Stepside died Downtown on the way in to work, I thought it was the Fuel Pump. After towing home, I R&R-ed the pump. That wasn't the right gripe. My HEI Module had burned out. Changed that, and it was fine.
I kept my known-good, old school fuel pump in the new box for the inevitable event later. I've been thru almost the exact same ''Fuel Pump Adventure'' as Richard J describes -- nearly word for word -- with the Fuel Pump on the 350 SBC in my '71 GMC Jimmy.
