Old 02-19-2025, 11:34 PM   #1
Dodge68charger
Trailer wiring harness help?
Id like to tow a teailer with my 69 C10 but never wired a truck wiring kit. I got some 7-way wire to splice under the dash. Do i just tap into the existing wires?
Turn/reverse/park/ etc.
Should i use a terminal strip and should anything be fused. Thanks
Dodge68charger is offline   Reply With Quote
Old 02-20-2025, 12:45 AM   #2
53burb
53burb's Avatar
Re: Trailer wiring harness help?
typically you splice into the connections at the rear of the truck by the taillights....are you planning on using the standard 4-way plug? if so, brakes, left turn, right turn, and ground. Most people just use t-taps to splice into the connections....although, they are not the strongest.
53burb is offline   Reply With Quote
Old 02-20-2025, 12:54 AM   #3
Rick Bollinger
If you are just pulling a flat trailer or most boats a flat four is all you need. If it is a camper with brakes and power then you do need a 7 pin. I have a 7 pin on mine and used this plug in for brake, tail and turn signal lights. with this there is no cutting just plug in at your tail light on back driver side of frame. https://www.bing.com/shop/productpag...29DD343ADD423E
If a brake controller is needed you need to run a 10 gauge wire to the back plug. Same way with a power wire to trailer for camper, 10 ga from battery, fused to the 7 pin connector. Hook up brake controller by directions with it.
Rick Bollinger is offline   Reply With Quote
Old 02-20-2025, 12:56 AM   #4
Dodge68charger
Going to run a 7 way plug
I need to run trailer brakes
Old 02-20-2025, 01:12 AM   #5
Dodge68charger
Thank You
Old 02-20-2025, 02:35 AM   #6
53burb
53burb's Avatar
i had the 4 way plug wrong....left/stop lights, right/stop lights, tail lights, and ground...I was looking for what Rick Bollinger posted...but didn't find it...,
Old 02-20-2025, 03:46 AM   #7
kwmech
One of the wiring supplies makes an adapter that plugs in between the frame rail harness and the tail lamp harness with a flat 4 coming off of it. Plug and play. No cutting or splicing needed. https://www.amazon.com/55311-Vehicle...72995910&psc=1
Left--yellow
Right--dk Green
Brown--running/tail lamps
white--ground
Anything other than a flat 4 you can cut the pigtail to length and use those wires in your receptacle and bring wires from the front of the truck back like the trailer brake wire (12ga blue) and a 12v off of a circuit breaker (black)
Old 02-20-2025, 11:18 AM   #8
Rick Bollinger
53burb click on the link it takes you to one. If you want Google the part number and name to find other vendors with one. I ran wires from the adapter to my 7 way and added the brake and power wires from the front.
Old 02-20-2025, 11:32 AM   #9
72c20customcamper
72c20customcamper's Avatar
the only wire coming from front under the dash is the brake wire coming from the controller. And the only splice under the dash was for the brake light wire to the controller. Brake/turn and running lights are all spliced at the rear of the truck .
Newer cars and trucks everything is done under the dash but it’s just a plug and play situation as most vehicles that are rated to tow are pre wired .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 02-20-2025, 11:34 AM   #10
PbFut
The plug in adaptor at the rear is the way to go. The 4 wire ribbon already on the truck provides all the tail light function. If you need a brake signal or +12V for accessories then a separate run is needed. I would wire in a 7 pin, even if all you need is a 4 wire now. This gives you the ability to connect anything in the future. As for brake controllers, there are many. I found a Curt controller that uses a smartphone. It is a fantastic controller and very easy to adjust. Has memory for multiple trailers. Way easier to wire because to don't need to penetrate the cab.
PbFut is offline   Reply With Quote
Old 02-20-2025, 02:21 PM   #11
Rick Bollinger
Pbfut I found one of thoes on clearance but have not tried it yet. I believe you would still have to run a power wire to the back to use it. The stock brake light wiring would not support the elect brake demand. I assume power comes from tha accessorie wire going to the 7 wire plug.
Old 02-20-2025, 02:53 PM   #12
PbFut
Correct. You need a +12v. It's been a few years since I wired mine. Can't recall 100% but I beleive the unit will sleep so a full time hot will not drain battery. I run full time hot from a aux rv battery with factory relay for isolation and charging. I do not recall max 12v amps through the device for accessories. I used to haul race car many many miles.
Old 02-20-2025, 11:19 PM   #13
slikside
slikside's Avatar
Subscribed.
Great info!
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor.
slikside is offline   Reply With Quote
Old 02-21-2025, 04:40 AM   #14
53burb
53burb's Avatar
Thank You!!
Old 02-21-2025, 05:41 PM   #15
MARKDTN
Curt 55311 says it fits 73-82 Trucks but Summit has a harness that fits 67-82 so is the plug at the back the same where it meets the rear harness? If so I would use this to tap into the existing harness and get stop/turn/tail/backup with no splicing.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 02-22-2025, 10:53 PM   #16
LockDoc
The Older Generation
LockDoc's Avatar
I just ordered 2 of these. We shall see.
https://shop.advanceautoparts.com/p/...1105/6253059-P
The Advance Auto store is still open in Des Moines, Iowa.
There is a good picture of the plugs on the Curt 55311 on the etrailer web site here....
https://www.etrailer.com/Custom-Fit-...RT/C55311.html
If you put in 1972 Chevrolet pickup it says it doesn't fit but it looks the same as the '67-'72 unless the wires are in different locations....
Leon
Old 02-23-2025, 03:40 AM   #17
mr48chev
mr48chev's Avatar
I bought a trailer wire junction box like this to put on my flatbed to get rid of the most horrific basket of snakes including a bunch of flat yellow extension cord like contractors use on the wiring at the back of the truck.
On my truck it just goes where it fit on the frame rail between the the crossmember that the factory plug is in and the back crossmember.
The wires from the front go in and to the proper posts, the lights on the truck hook to them and the trailer plug wires connect up. That cleans up a real mess that had too many hands in it over the years and makes changing or trouble shooting pretty simple,
The only issue on a truck with stock taillights might be the length of the wire and if you are able to cut the wires to put terminals on them and hook them to the pins in the box without stretching the wires.
My ongoing truck projects:
