Old Yesterday, 11:33 AM   #1
72Mountaineer
72Mountaineer's Avatar
Brakes - 1st pump nothing
64 C10, front power disc conversion, Camaro rear end w/drum brakes, everything new (power unit to caliper/rear cylinders), rod from pedal to power unit moved down 1", all brake lines bled out the ass. First pump goes to the floor, 2nd pump is good. WTF?
72Mountaineer is offline   Reply With Quote
Old Yesterday, 12:24 PM   #2
SkinnyG
SkinnyG's Avatar
Re: Brakes - 1st pump nothing
Are the drums adjusted correctly? They should slightly drag when turning the drum.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is online now   Reply With Quote
Old Yesterday, 12:26 PM   #3
bhap
bhap's Avatar
Ask a professional, but I think there ishould be a redidual pressure valve to keep the shoes closer to the drums so your first pump isn’t “empty”. They might be incorporated in disc/drum master cylinders or proportioning valves - someone with better knowledge can answer.
bhap is offline   Reply With Quote
Old Yesterday, 06:31 PM   #5
jweb
jweb's Avatar
I would do what was recommended above and check the adjustment on the rear drums, this seems to be really common.
Did you bench bleed your master cylinder?
Even with the master cylinder on the firewall they recommend a residual valve.
Drum brakes require the use of a 10 Ib residual pressure valve in the line. This residual pressure counter balances the drum brake spring tension keeping the shoes close to the drums. This results in a higher firmer pedal. You can test this by clamping off the rear hose removing the rear drums from the system. Now test your pedal. If the pedal gets better you will need to splice a 10 Ib residual pressure valve into the rear line.
1951 Truck, LS1/4L60
1964 Suburban, current project
jweb is offline   Reply With Quote
Old Yesterday, 08:53 PM   #6
72Mountaineer
Yes, the rear drums are adjusted correctly, maybe even a little tight. I've been doing this stuff for 60 years, and it all points to air in the system. Yes, I bench bled the MC. Bled the system more than once (ask the wife, shes an expert over the years at pedal pumping), even used a pressure pot, no change. When you say clamp off the rear hose, do you mean the hose over the rear axle? I have never heard of the fact of all drum brakes need a residual valve. I have set up and replaced many older systems and have never used (or seen) residual valves in a stock system. I set up my '53 Chevy with residual valves, as is required of a MC lower than the calipers, and the brakes worked better without them. But I've never even heard of putting valves in a system with the MC on the firewall.
Old Yesterday, 10:41 PM   #7
AcampoDave
AcampoDave's Avatar
Is the MC pushrod adjusted so that the piston can fully retract to the resting position when the pedal is released.
AcampoDave is offline   Reply With Quote
