Old 02-21-2025, 12:59 PM   #1
BRL
BRL's Avatar
Battery plug?
Got a new battery and this plug thing was carefully placed under the negative post protector.
Already tossed it in the trash but I can dig it back out if need be.
Anybody know what it's for?
BRL is offline   Reply With Quote
Old 02-21-2025, 01:07 PM   #2
HotWheelsFan
HotWheelsFan's Avatar
Re: Battery plug?
Maybe a thread protector for side post battery terminals?
Bob
HotWheelsFan is offline   Reply With Quote
Old 02-21-2025, 01:32 PM   #3
BRL
BRL's Avatar
Wink Re: Battery plug?
I considered that possibility but this battery doesn't come with side posts.
Maybe somebody mistakenly added it because one would think that the positive post would be the one to be protected with a red plug but none was included.
I just tossed it and was having second thoughts about that idea.
Haven't even used the battery while driving yet so now would be the time to find out if I needed it.
Old 02-21-2025, 07:48 PM   #4
weq92f
weq92f's Avatar
Re: Battery plug?
No scale in the image of the "plug" so don't know how big it is. But if it was under the post protector, it must be small. Check around the edges of the battery case for some place to plug that thing in. I think your battery has a vent and this is a nipple for vent hose.
Total wild guess though.
-Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 02-21-2025, 08:15 PM   #5
54blackhornet
54blackhornet's Avatar
Re: Battery plug?
Not sure about that plug thing but that style positive cable clamp is questionable.
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 02-21-2025, 09:04 PM   #6
Killer Bee
Killer Bee's Avatar
Re: Battery plug?
group 24F is a common Japanese car battery, same battery in Mrs. Bee's lexus wagon
batteries installed inside the passenger compartment have to be vented outside
the plug is to cover the vent hole opposite the side the vent tube is installed
for your installation in the engine compartment you can disregard the plug
Old 02-21-2025, 09:56 PM   #7
BRL
BRL's Avatar
Re: Battery plug?
What's wrong with the clamp, been working great forever.
Originally Posted by Killer Bee View Post
...for your installation in the engine compartment you can disregard the plug
That's great news, you're my new best friend!
I was headed to town and noticed my volt meter wasn't up to where it should be.
I suspected a bad alternator so I headed to NAPA because it had a lifetime warranty.
Guy tested it and said the battery was good but maybe the regulator went bad so I replaced the alternator in the parking lot.
No change on the volt meter so I had them retest the system.
This time they said the battery was bad but didn't make me return the alternator so I was happy about that.
When swapping alternators I noticed my junkyard plug was a total disaster so I'm swapping that out.
Old 03-01-2025, 05:24 PM   #8
BRL
BRL's Avatar
Re: Battery plug?
Originally Posted by BRL View Post
...I noticed my junkyard plug was a total disaster so I'm swapping that out.
Between the new battery, new alternator, (rebuilt) and my new alternator plug this truck is charging wonderfully.
I do love it when things go right.
Old 03-01-2025, 09:29 PM   #9
dmjlambert
dmjlambert's Avatar
Re: Battery plug?
I had terrible experiences with emergency repair battery terminals like these.
Name:  Screen Shot 2025-03-01 at 7.02.52 PM.jpg
Name:  Screen Shot 2025-03-01 at 6.53.58 PM.jpg
I had a high resistance connection although the wire was inspected, freshly cleaned and re-inserted and tightened into that &#$?&! terminal. It's my own fault for misdiagnosing needing a starter, which led to me getting a new starter, and improper shimming of the starter led to me chewing up the flex plate, and I still had starting problems. I was fuming. Then I had a saga trying to replace the battery cable with one obtained through brick and mortar channels, eventually led to fixing the problem. And changed the flex plate. Anyway I swore off emergency repair battery terminals. I have bookmarked a discussion about Battery Cables USA, and will buy from them next time I need a battery cable. I'll have them add 12 gauge accessory wires to send voltage to my fender-mounted junction block with fusible link.
dmjlambert is offline   Reply With Quote
Old 03-02-2025, 04:06 AM   #10
BRL
BRL's Avatar
Re: Battery plug?
Wow now I understand.
Sorry to hear you went through so much trouble diagnosing the problem, I've never experienced any issues but now I'm wondering just what I might be looking for as far as a new positive and negative battery cable goes.
ETA: I read your post on the battery cables/terminals...wow!
Old 03-03-2025, 08:16 AM   #11
BRL
BRL's Avatar
Re: Battery plug?
Oh yea, I may as well show you all the other half of my gauge cluster since I'm awake at 4AM and I had a picture of it.
I filled in that blank spot on my cluster with a B&M transmission temperature gauge and put blue lighting behind everything to match my radio.
Getting ready to install an electric fuel pump so I mounted my inertia switch upside down in a convenient spot and have since painted the cap black to make it disappear. (works fine)
I have a subwoofer enclosure between the bucket seats so nobody will be sitting there kicking the switch and shutting off the fuel supply.
OK back to sleep. zzzzz
Old 03-03-2025, 09:45 AM   #12
70STOVEBOLT
70STOVEBOLT's Avatar
Re: Battery plug?
There is nothing wrong with that type of battery terminal, as long as the cable is inserted all the way and the bolts/nuts are all tight. Yes, the proper thing to do is to replace the entire battery cable, but that terminal will work just fine.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 03-03-2025, 10:31 AM   #13
BRL
BRL's Avatar
Re: Battery plug?
Originally Posted by 70STOVEBOLT View Post
...Yes, the proper thing to do is to replace the entire battery cable, but that terminal will work just fine.
Yea I've never had a problem with them other than the bolts that hold the cable loosening up sometimes, and I probably split a clamp or two from over tightening them on the post, but that is definitely a possibility to be aware of.
