![]() Join Date: Jan 2025
Help finding HEI dist. and will I loose my factory tach
I am looking for a part number or link to which ACDelco / GMC brand HEI ready to run dist. would work in my truck - so far I haven't found one.
After a lot of searching here I can't determine if i would loose my factory dash tach or if it would work with an adaptor.
1972 C10 Custom Deluxe Highlander 402 Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility. |
| Bookmarks |
