Old 02-24-2025, 08:49 PM   #1
H8tulooze1
H8tulooze1's Avatar
Center link location
Does the center link matter which way its installed? LMC Diagram shows from the bottom up. I have mine mounted from the top down. Which is the correct way and if installed incorrectly will it cause the truck to wander? Bottom image is from Motor City K5.
1967 Nova SS LS9 900HP
1965 Chevelle 2-Door Wagon F/S
1972 K5 Blazer 5.3
H8tulooze1 is offline   Reply With Quote
Old 02-25-2025, 02:55 AM   #2
Richard
Re: Center link location
Typical early model tie rod end is nut down, late model is nut up. Cannot remember exact year change was made. Though I can say 72 and earlier is nut down. If 70 or earlier truck with disk brakes the axle may have been swapped with a later model axle. Note that the taper in the knuckle would most likely prevent even grabbing a few threads if installed wrong.
Richard
Old 02-25-2025, 10:02 AM   #3
hemi43
hemi43's Avatar
It can only be mounted one way because the taper in the tie rod ends. If it could be mounted upside down, the truck would still drive normally.
My 70 has the nut facing down.
Edit; Sorry Richard, I read your reply after posting mine.
hemi43 is online now   Reply With Quote
Old 02-25-2025, 11:21 AM   #4
H8tulooze1
H8tulooze1's Avatar
Thanks for the info guys!
1972 K5 Blazer 5.3
Old 02-27-2025, 02:41 PM   #5
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: Center link location
The change in tie rod end design was in 1973 to nut up. 1967-72 K series tie rod/ends are all interchangeable. GM 6273901 or DANA 36141 RH thread and GM 3273902 or DANA 36142 LH thread.
