![]() Join Date: Jul 2023
18 guage hand held hole punch for replacement panels
I have looked hi and lo for a hole punch that will pierce 18g metal
I have only found ones that handle 16g I don't want to drill. Can anyone steer me to a HAND HELD punch for 18g A pneumatic tool I is not what I want. The hand held tool that has rotating wheel with the different hole diameter sizes. |
![]() Join Date: Dec 1999
Re: 18 guage hand held hole punch for replacement panels
16g is heavier than 18.
Ron
Member #111 68 C-10 Daily Driver70 4x4 Project76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
![]() Join Date: Jun 2005
Yep, like wire, the smaller number the larger the size.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
Wow. Just electric wire sizing
I'm so glad I'm a member of the forum. Lastly, do you all use .023 mig wire for the panel welding ? |
I typically use .030 on sheet metal. And then .035 on thicker steel.
The thing about welding thin sheet metal is practice practice practice on the same gauge sheet metal before welding on your project. |
If you already have 023 it will work just fine. Don't use flux core wire it is dirty. Using 25% carbon dioxide 75% argon gas for black is the cleanest.
My bad I was backwards on the blend brain fart. Thanks raggedjim. Last edited by Rick Bollinger; 02-26-2025 at 09:17 PM. |
![]() Join Date: Jun 2002
Hmm, I always use 75% argon, 25% CO2.
I use .030 for floor panels but usually use .023 for outer body panels. I have used flux core for floor panels but you get a lot of splatter. If you have a flux core/mig machine make sure you select the right polarity for mig. Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
#8 | |
#9 | |
here is a pic
cbeerman That is one of the good ones. I have one like it and another in the blue plastic box. It also is a quality punch. Both Roper Whitney. Avoid the cheap knock offs they are junk I have used them. I'm a 38 year Union Sheet Metal worker and am retiring on March 14th. Spend the extra and it is a lifetime tool if taken care of.
I bought a Chief air operated one from HF and have had good luck with it as well. also is a seamer.
1967 GMC C25 305 V6 1969 K20 CST 1994 k1500, Oldredz71(ext shorty 4x4 6 in lift) 1998 S10ZR2 2001 Silverado 2500hd 8.1L 2003 Silverado 2500hd Crew cab |
#13 |
That is the exact same punch I have.
FWIW, I have a HF flux core MIG that I converted to DC and it works great, not as dirty as before and with less spatter. I have used it on all my cab welding and it has been excellent. Just saying...maybe the DC conversion is the difference. |
| Bookmarks |
