Old Today, 02:26 PM   #1
IT Cowboy
IT Cowboy's Avatar
Location: Clarkdale, Arizona in a van down by the river
What carb to replace my Quadrajet
My Quadrajet needs to be rebuilt and my mechanic says $480 for removal and rebuild so I am just thinking about replacing it with an Edlebrock. Supposedly they come almost all adjusted and are easy to tune. So which one should I go with Someone on another site suggested the AVS 19069 as a newer better option than the 1406
'72 C10 / 402
___________________________________________
Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility.
IT Cowboy is online now   Reply With Quote
Old Today, 02:43 PM   #2
Willshook
Re: What carb to replace my Quadrajet
The average mechanic can't reliably overhaul a Q-Jet. I know people will take exception to that, but I have yet to see an "overhaul" come out of a regular (non-classic or hot rod specialty) shop that wasn't FUBARd.
That said, not all that hard to do with parts and guidance (plus patience) from Cliff Ruggles Performance.
Edelbrock carbs require less tuning in a stock application, which is good because they are less tunable
https://www.holley.com/products/fuel...parts/0-80555S
Specific Q-Jet replacement, including being spread-bore which works exceptionally well on our trucks since we cruise on the smaller primaries but can get some CFM if we need it from the huge secondaries. Extremely tunable like all Holley carbs but often requires some time to dial it in on initial installation for peak performance, drivability and economy.
Just remember that if you buy a square-bore carb you'll need an adapter.
Willshook is offline   Reply With Quote
Old Today, 04:18 PM   #3
geezer#99
geezer#99's Avatar
I’d get one of these before I had a mechanic touch mine.
https://quadrajetpower.com/chevrolet...rajet-7042206/
They’ll even rebuild yours if you want.
Old Today, 04:29 PM   #4
ron350
ron350's Avatar
If you have the erg to replace the Q-jet just bang your head against the wall till that erg goes away.
The Q-jet is one of the best carburetors ever made.
If you can use hand tools and can take pictures any one can rebuild a Q-jet with this book.
https://www.amazon.com/Rochester-Car.../dp/0895863014
I still have my copy from 1974.
Stock 75 C10 step side.
350 2 BBL, 350 trans. 150K miles.
ron350 is offline   Reply With Quote
Old Today, 05:16 PM   #5
LS short box
Over on corvetteforum.com the is a member that's called "Lars". He is the go to guy for rebuilding QJ's. He gets great reviews.
LS short box is offline   Reply With Quote
Old Today, 06:07 PM   #6
IT Cowboy
IT Cowboy's Avatar
I am trying to figure out if rebuilt is worth it for the same or less than a new one
'72 C10 / 402
