Possible to install 1971 upper ball joints in 1974 control arms?
I am trying to figure out if I can make this work. Have a 1974 C10 full front suspension. I also have a set of 1971 C10 drop spindles I would like to run. So my question is, I believe the lower ball joints are the same between the 1971 and 1974 (.855"), but I think the tops are different, 1971 (.682") 1974 (.716"). Can I just replace the 1974 ball joint with a 1971 ball joint? Will a 1971 ball joint bolt into a 1974 control arm?
Are there other issues I might have? Will using a 1971 spindle with the 1974 tierods work or are those different also? |
#2 | |
The Older Generation
Re: Possible to install 1971 upper ball joints in 1974 control arms?
http://67-72chevytrucks.com/vboard/s...d.php?t=444823 .
#3 | |
I think I got my answer regarding the tierod. Looks like I will have to use a 1971 outer with the 1974 inner and tierod sleeve (looks like both 1971 and 1974 have 11/16 threads). The thread also confirms that the 1971 and 1974 upper ball joints are different. What I don't see is if a 1971 ball joint will bolt into a 1974 control arm. |
67-72 parts collector,…
![]() Join Date: Nov 2002
Yes the 71-72 upper balljoint will bolt into a 1974 c10 control arm.
| Bookmarks |
