Old 02-26-2025, 11:57 PM   #1
Ziegelsteinfaust
Heater/Ac ducting control
After a couple of years of just ignoring the poor wiring, and heater issues of my truck. I have decided to fix it so I can sell it to fund the purchase a Suburban or a wagon. My son, and I need a vehicle with more interior room for our winter trips.
So while the heater now works alot better, and shuts off fully. I can not switch the places the air comes out of. If i move the lever. It mostly still comes out the bottom.
Where is a good place to start to look for the issue?
Ziegelsteinfaust is offline   Reply With Quote
Old 02-27-2025, 08:23 AM   #2
Willie Makeit
Willie Makeit's Avatar
Re: Heater/Ac ducting control
check the vacuum lines. my bet is one or more is either missing or broken
Willie Makeit is offline   Reply With Quote
Old 02-27-2025, 09:43 AM   #3
Dead Parrot
Does it still have the round ball on the firewall and vacuum line to the engine manifold?
Dead Parrot is offline   Reply With Quote
Old 02-27-2025, 11:20 PM   #4
farmall
farmall's Avatar
I dont remember what year your truck is.
Here is what I have saved for mine.
1955 GMC 250 8 Flatbed
1971 C30 157" 350 4spd 10' Flatbed
81 GMC K30 CnC 9' Flatbed 454 T400
89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958
71 LT1 Convertible, 72 Coupe
69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2
farmall is offline   Reply With Quote
Old 02-28-2025, 04:20 PM   #5
Ziegelsteinfaust
Yes. It holds vacuum. I also t tested it by setting the engine to high idle with it removed, and it made no difference.
Old 02-28-2025, 04:21 PM   #6
Ziegelsteinfaust
Mine is a 83.
It was missing a couple lines, and I don't have the T on mine.
What sub gen is that diagram from?
Old 02-28-2025, 04:23 PM   #7
Ziegelsteinfaust
I hear hissing somewhere, but over my engine and exhaust. It's hard to pin point.
I will have my son help me this weekend.
Old 02-28-2025, 05:12 PM   #8
Dead Parrot
Hissing could be from a bad diaphragm in one of the the vacuum pots that move the flappers. Or a missing/broken hose.
On my 75:
The Side Shroud should open when the control is set to MAX AC. It is over by the passenger kick panel.
There is one near the throttle pedal that operates the Defrost/heat flapper.
The third one is buried behind the dash and operates the bi-level flapper.
There may be one for Vent.
The flapper for Heat/Cold is a manual cable
I think most of the squares are similar.
Old 02-28-2025, 10:30 PM   #9
farmall
farmall's Avatar
https://www.73-87chevytrucks.com/tec...ice_Manual.pdf
Page 81
