Old 02-27-2025, 08:37 AM   #1
IT Cowboy
IT Cowboy's Avatar
Brake pedal squeak help and suggestions
I have a brake pedal squeak I cannot find, I did a search here with not a lot of help. When I pump the brake pedal it is more of a chirping sound and it sounds like it is inside but I cannot tell. I have sprayed white grease and WD40 on the linkage under the dash and under the hood and no change. Possibly a worn bushing or the diaphragm in the booster? Any suggestions or ideas and maybe someone else has had this before.
1972 C10 Custom Deluxe Highlander 402
Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility.
IT Cowboy is offline   Reply With Quote
