Old 03-01-2025, 04:05 PM   #1
HeavyHauler
Installing new wiring harness for heater blower motor and dash switch in my 68 C10
Later this afternoon I will be installing a new wiring harness for the heater blower motor in my 1968 Chevy C10 which only came from the factory with a heater and no AC.
There is a brown wire that goes from the blower motor switch at the dash controls to the fuse panel?
I see the heater fuse in the panel but I am wondering how that brown wire connects to the fuse panel and where?
Any help is appreciated and thanks.
HeavyHauler is online now   Reply With Quote
Old 03-01-2025, 07:38 PM   #2
HO455
HO455's Avatar
Re: Installing new wiring harness for heater blower motor and dash switch in my 68 C1
I believe this thread will answer your question. VetteVet explains it well.
http://67-72chevytrucks.com/vboard/s...d.php?t=662676
RIP Bob Parks.
Old 03-01-2025, 09:21 PM   #3
HeavyHauler
I will give it a read! Thanks!
Old 03-02-2025, 09:21 AM   #4
HeavyHauler
Well I looked at my fuse box and I cannot find any 14 gauge brown wire coming from the fuse box at all. I looked at the heater fuse area and I dont see anything at all.
I dont see any brown wire coming from behind the box either. I know the brown wire is supposed to be coming from the fuse box as illustrated by the wiring diagram but I am not sure exactly where it should be.
Because if it is not there at all I want to put one back where the factory had it.
Old 03-02-2025, 05:00 PM   #5
HO455
HO455's Avatar
Scroll to post 6 in this thread VetteVet shows where the 14 brown originates in the fuse block.
http://www.67-72chevytrucks.com/vboa...d.php?t=603792
It's possible that the 14 brown was damaged at some time in the past and was cut out like mine was. A PO of my truck cut the 14 brown off and spliced a new wire and plugged it into one of the unfused terminals on the fuse box. See photo. The small arrow points to the 14 brown where it goes into the heater switch plug. Where the PO spliced a blue to it and off camera a yellow wire was spliced to that.
The 14 brown should be coming out of the end of the main harness above the gas pedal.
In the second photo the green arrow points to the plug for the heater resistor. The red arrow points to the heater switch plug and the yellow arrow points to the #14 brown wire that comes from the fuse. Thanks to J2-72 for the photo.
I hope this helps.
RIP Bob Parks.
Old 03-03-2025, 12:29 AM   #6
HeavyHauler
Yes this is a big help. I am just going to run a 14 gauge fused wire from the unfused ignition terminal at the fuse box back to the heater control switch on the dash. I am going to run the same size of fuse that is labeled heater at thef fuse box.
I was going to unbolt the fuse box from inside the cab and run the brown power wire from the factory location but my luck would be there is something broke back there and that is why the other PO never used it. LOL! It will be more accessible if I just run a brown power wire from the front of the fuse panel anyways.
I am also going to check and see when those unfused ignition terminals get power when I turn on the key.
Thanks again!
