![]() Join Date: Dec 2024
Help with 70 cpp front suspension on a 71
Recently purchased cpp tubular an arms, drop springs, shocks and 2 inch drop spindles for my 71 from a friend who used them only for a mock-up. What I just found out is 67-70 trucks are different from 71/72 trucks, what problems will I run into installing these parts?
I’m considering buying the cpp front linkage kit to make everything fresh, but what kit should I buy 67-70 or 71/72? I also need upper ball joints for the arms, and have no idea what ball joints to buy. I plan to call cpp to bother them with these questions, but figured I’d drop in here to see if anyone can help me Posted via Mobile Device |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Help with 70 cpp front suspension on a 71
Balljoints and steering component need to match the year spindle you are going to use.
#3 | |
ball joints I’ll have to match those 63-80 spindles. How about my existing hub and rotor, will they work on the new spindles I have ? Posted via Mobile Device |
#4 | |
Balljoints need to match the year of spindle. If the spindle is a 63-70 conversion spindle you need 63-70 balljoints. The outer tie Rod needs to match the year spindle also. The problem is the 63-70 outer tie rod is 5/8 left hand thread. The 71-72 outer tie rod is 11/16 right hand thread. The taper in the spindle is also different. You can with buy all new steering for a 63-70 truck or use aftermarket tie rod adapters that are threaded 5/8” on one end and 11/16 on the other. The 63-70 trucks use a different center link than the 71-72 trucks. Look at the link in my signature. Lots of info there.
FOR YOUR SPECIFIC PROBKEM,… ie 71-72 truck trying to run 63-70 spindles,…
You need either: 1) 63-70 centerlink and 63-70 inner and outer tie rod to go with your 63-70 spindles. OR 2) use your existing 71-72 center link and run your 71-72 OUTER tie rods at the inner location and connect them to a 63-70 outer tie rod (with the above mention conversion tie rod sleeve) to connect to your 63-70 spindle. OR BETTER YET 3) Buy 71-72 drop spindles. This will allow you to use all your original steering by swapping the balljoints in the CPP control arms to 71-72 balljoints.
Wow keith thanks for that knowledge. The way I look at it is I’ll buy a complete 67-70 steering kit, as cpp sells the kit (part #6770DSLK-CP-C10) for $329, and 71/72 spindles are the same price, but I’ll still be stuck with my old steering linkage. So this way I’ll be all new linkage and everything.
| Bookmarks |
