Old 03-02-2025, 01:52 PM   #1
HeavyHauler
Could I wire heater blower motor switch to fuse box using unfused spade on fuse box?
On my 68 C10 I dont have a brown power wire from the heater blower motor switch on the dash that leads to the fuse box. My C10 is a factory heater only truck.
I plan to make my own power wire and plug it into the fuse box at the terminal that is labeled IGNITION UNFUSED. I figure that I will add an inline fuse the same as what the heater fuse is.
Will this work without causing problems? I already installed a new blower motor harness which connects the blower switch at the dash to the blower motor resistor and to the blower motor.
HeavyHauler is online now   Reply With Quote
Old 03-02-2025, 10:00 PM   #2
HO455
HO455's Avatar
Re: Could I wire heater blower motor switch to fuse box using unfused spade on fuse b
Yes you could. My Burban was wired that way when I got it.
RIP Bob Parks.
Old 03-02-2025, 10:09 PM   #3
truckster
truckster's Avatar
As long as you do it the way you describe, with an appropriately rated inline fuse.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
1972 K/5 Blazer CST 4WD
1963 Corvair Monza Spyder Turbo convertible
1995 Camaro Z/28
truckster is online now   Reply With Quote
Old 03-02-2025, 11:55 PM   #4
HeavyHauler
Awesome! Thanks guys. I wasnt sure how difficult it would be to remove the fuse box and run it from behind the box but this way would seem to be just as good.
