Old 03-02-2025, 02:00 PM   #1
Rich69shortfleet
Fuel pump PITA
So, the fuel pump on my sb400 in my 69 C10 started leaking pretty bad. It was probably 25-30 years old so not a huge surprise. It was a pretty run of the mill stock pump when I put it on.
So, since the engine is basically stock I got the stock replacement pump that was readily available at the local parts store. It went on without much trouble.
So, I got it running after the new pump went on and it ran fine for a while and then started flooding out the engine. Come to find out that the run of the mill replacement pumps put out 7.5-9 psi of fuel pressure which is more than a stock Quadrajet really likes. Fuel was leaking out of the carb and into the intake pretty readily.
So, I decided to rebuild the carb since it has been a while. No big deal, used a good gasket kit and installed a new float just to be thorough. Since the only pumps that put out the more reasonable psi amounts (Edelbrock and Carter) cost a ridiculous $150 or more, I decided to put a fuel pressure regulator on the system instead. This would allow me to put on a typically available pump if I had a failure out on the road and with the regulator would be able to keep it going regardless of the pump I ended up with.
So, I got it all buttoned up today and it started right up. Shut it down and checked for leaks. All was good, had the regulator set at 4.5 psi. But, while I was messing around putting the air cleaner back on and rechecking all the connections, the carb started flooding real bad again and it wouldn't start since there was so much liquid fuel in the intake.
So, either the regulator stops regulating when the engine shuts down or it isn't working in the first place. So, I"m probably left with using one of the expensive fuel pumps anyway and I'm sure I can't return the current pump or regulator at this point.
Why can't replacement part manufacturers just make parts that will work with our old stuff without having to jack around to find the right stuff, spend more than is really needed and/or having to install yet more components just to make it would like it should in the first place?
My truck used to be one of the most reliable vehilcles I've owned, but this is ruining its reputation.
Rich69shortfleet is offline   Reply With Quote
Old 03-02-2025, 02:05 PM   #2
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: Fuel pump PITA
People chuckle when I boast of running NOS AC fuel pumps on my vintage rides. They are to be trusted more than anything made today. I don't run ethanol fuel in them, so that isn't a thing.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
2017 Sierra 1500 SLT 4WD, Black, 46k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 67k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 03-02-2025, 02:20 PM   #3
Accelo
Accelo's Avatar
Re: Fuel pump PITA
Your issue isn't uncommon.
Fuel Pressure is determined by the spring in the pump, and they don't care about getting it correct. I am assuming the new pump is the crimped-style pump.
The pumps with screws can be taken apart, and the spring trimmed to adjust the pressure.
The options seem to be an OEM pump or adding a fuel pressure regulator.
I'm guessing the pressure regulator is also China. You may be able to have someone watch the gauge while the engine is shut down.
I agree. All possible value has been removed from almost everything. Guess that is the outcome when only price matters.
I just purchased a new pair of Levis. Took the information right off my old ones.
Old Levis were made in Mexico, the new ones were manufactured in China.
They were physically lighter than the old pair.
Accelo is offline   Reply With Quote
Old 03-02-2025, 02:20 PM   #4
Rich69shortfleet
Re: Fuel pump PITA
Yeah, I had the original pump on my L79 in the Chevelle rebuilt since no aftermarket pump would ever keep the Holley happy properly.
Nothing I drive gets ethanol. Luckily I live in a rural area where gas stations make a point to sell 100% gas at most places since there are still farm equipment and trucks around that don't want ethanol in them.
But geez parts manufacturers, just make a stock replacement pump that puts out the correct 5.5 psi for a carbureted small block. QJs are the most common carburetor on the planet yet they can't make a pump any more (that isn't a specialty pump) that will work properly with a QJ?
Old 03-02-2025, 02:23 PM   #5
Rich69shortfleet
Re: Fuel pump PITA
Originally Posted by Accelo View Post
Your issue isn't uncommon. Fuel Pressure is determined by the spring in the pump, and they don't care about getting it correct. I am assuming the new pump is the crimped-style pump.
The pumps with screws can be taken apart and the spring trimmed to adjust the pressure.
Yep, crimped style pump. Couldn't find anything else that is readily available for a reasonable price. Even the supposedly "will work correctly" Carter at $150 puts out 7 psi.
Old 03-02-2025, 02:35 PM   #6
Rich69shortfleet
Re: Fuel pump PITA
The Delphi MF0001 pump is harder to find but says it runs at 5 psi. I'm skeptical and am already tired of throwing parts at this thing and smelling like gas but I'm not sure what else to try.
Has anyone had any experience with this Delphi pump?
Old 03-02-2025, 02:48 PM   #7
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
Re: Fuel pump PITA
Several months back I had a couple different parts stores try to order that pump only for them to tell me they couldn't get it. Good luck
67 C10 283 T5 swapped longbed fleetside = wife's daily driver
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
Old 03-02-2025, 03:01 PM   #8
72c20customcamper
72c20customcamper's Avatar
Re: Fuel pump PITA
I was told if the pressure regulator doesn’t have a return once the engine is shut down it could bump up the pressure over what it’s set at . I bought a pump from Summit when I put the new engine in . It was a Delphi unit I bought a regulator and a gage . I put the gage in first and it was running at 5.5 psi so I never did install the regulator
Edit : Just looked at my receipts and it was this pump from Rock Auto they also have the 0001 pump for no return line
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 03-02-2025, 04:58 PM   #9
Rich69shortfleet
Re: Fuel pump PITA
My fuel system and pump has just two lines, no return.
Old 03-02-2025, 05:02 PM   #10
RichardJ
Re: Fuel pump PITA
The Carter and the Delphi are the same pump.
I just went through the same mess with a pump for my 292 6 Cyl.
Inside the Carter and the Delphi box was a clear bag with instructions and the gasket. Both bags had the same part number tag on them. I called Carter and after some back and forth, he finally admitted, they were the same pump. Basically, someone in China makes both.
The 7 psi Delphi and the 5 psi Carter, both put out 14 psi.
I have a Jegs, 4 1/2 to 9 psi, Holley style regulator set at just below 5 psi. When I turn the engine off, the pressure goes up to about 9. The carb doesn't leak and I never checked to see how long the pressure stays up.
The Carter guy made the claim that they are aware of the problem and are in the process of fixing the problem in all their mechanical pumps.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 03-02-2025, 05:27 PM   #11
72c20customcamper
Re: Fuel pump PITA
This is the one you would need
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 03-02-2025, 05:31 PM   #12
72c20customcamper
Re: Fuel pump PITA
On my 68 I used this one no return line . Expensive but works well no regulator needed so far
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 03-02-2025, 06:42 PM   #13
57taskforce
All about them K’s
57taskforce's Avatar
Re: Fuel pump PITA
Damn you could run a tbi off of that pump. Thats crazy high for a carb. The off the shelf orielly special pump on my K20 has never given me any trouble, and im runny an eddy 1405 which is supposed to be just as picky as a quadrajet on fuel psi. seems pretty crazy to have a 5 lb pump pushing 14.
Tyler
57taskforce is offline   Reply With Quote
Old 03-02-2025, 06:48 PM   #14
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: Fuel pump PITA
Got a nos for a 454 and it still made 9 psi
Added a holley regulator at 5 psi runs fine now
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 03-02-2025, 08:54 PM   #15
Hugh in NC
Hugh in NC's Avatar
Re: Fuel pump PITA
I just bought and installed this one...So far, so good.
https://www.summitracing.com/parts/TSN-JM1003BK
Hugh in NC is offline   Reply With Quote
Old 03-02-2025, 09:56 PM   #16
Rich69shortfleet
Re: Fuel pump PITA
In reading some older threads on here it appears those have now become hit or miss with many putting out 9-10 psi.
It shows rated at 7.5 psi which would still be a little high for a QJ.
Old 03-02-2025, 09:59 PM   #17
Rich69shortfleet
Re: Fuel pump PITA
I saw those. They are an offshore knockoff of the Edelbrock 1721. Might be a workable choice. Are you running a QJ?
The other two options appear to be:
1. Edelbrock 1721, made to work with Edelbrock carbs that don't like anything more than 6 psi.
2. Carter M6900, some say rated at 6 psi, some say rated at 7 psi. Mixed reviews on them with some saying they USED to put out 6 psi but recent versions do 9-10 psi and even Carter has acknowledged the problem.
Old 03-03-2025, 08:49 AM   #18
1970cstblazer
Thumbs up Re: Fuel pump PITA
The original AC part number for the small can pump is 40987.
Old 03-03-2025, 09:33 AM   #19
1970cstblazer
Talking Re: Fuel pump PITA
Originally Posted by 70STOVEBOLT View Post
Do you know the Delco part number for the pump that fits a 1971 402 engine?
GM 6470424 or AC 40727
Old 03-03-2025, 09:50 AM   #20
Rich69shortfleet
Re: Fuel pump PITA
I actually found a few NOS versions of that pump on ebay. But wouldn't they go to ruin if ethanol laced gas were used with them? Like I've said above, I use only 100% gas locally, but if I have to travel sometimes gasahol is the only choice.
Old 03-03-2025, 09:58 AM   #21
1970cstblazer
Another one of those "your results may vary". I have ran a couple of them with limited amounts of E10 in them, and no issues. If there was to be a steady diet of the corn juice in them, then yeah, you might eventually have an issue with a ruptured diaphragm. That is the ONLY advantage of the new pumps sold today.
Best scenario is to score a correct vintage logo pump, and send it out to be rebuilt with a ethanol resistant diaphragm.
Old 03-03-2025, 10:15 AM   #22
Willshook
Re: Fuel pump PITA
The problem isn’t the fuel pump or regulator; you noted you overhauled the carb at the same time; there’s a mistake in there somewhere.
Regardless - don’t guess; CHECK the pressure.
I’ve had zero issues with name-brand replacement pumps having too high fuel pressure.
Willshook is offline   Reply With Quote
Old 03-03-2025, 10:30 AM   #23
72c20customcamper
Re: Fuel pump PITA
Didn’t have any problems with the 68 with the QJ. I used it for about 1k miles changed it out to an older AFB .
Only times I’ve ever had a problem was with fuel boiling in the bowls . And that was when I had to use 10% E gas . I run non E in all my carbureted vehicles
The only truck /car I have with a QJ is my 85 K20 I did change out the fuel pump a few years ago to the Delphi unit no problems at all with it . But I guess it’s like everything you buy today it’s hit and miss .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 03-03-2025, 11:06 AM   #24
Rich69shortfleet
Re: Fuel pump PITA
Well let's see, it was flooding out after the new pump but before the carb rebuild. It is flooding out after the new pump after the carb rebuild. The issue is the pump, not the carb. I've rebuilt enough carbs that I know what I'm doing there.
The pressure is over 10 psi with this pump. It appears the regulator can handle it on the first start up but when the engine is shut down the pressure climbs and floods the carb making a restart nearly impossible.
You do understand how a regulator typically works, right? They typically reduce the size of the opening for fuel flow so that the pressure on the upstream side of the fuel flow is lowered. However, when the fuel stops flowing, the pressure can still build on the upstream side to equal the pressure on the downstream side. I wish I'd understood this a little better before installing the regulator.
The ultimate answer is going to be a fuel pump with the CORRECT pressure output. The trick is actually finding one where that is the case and can be trusted to be the case. It is apparent that most manufacturers are more interested in selling parts than making parts that are actually correct for the application.
Old 03-03-2025, 11:12 AM   #25
Willshook
Re: Fuel pump PITA
You've of course verified this with a trusted gauge.
Yes, I know how it all works, thank you
Easy enough to test using a gravity feed bottle.
Good luck!
