Old 03-03-2025, 12:40 PM   #1
Loose Screw
Loose Screw's Avatar
Important! GATES Rubber Fuel Line! Read!
My email to Gates:
Their Reply:
I have made (2) other threads about Fuel Delivery within the past month.
I feel this is Important To Know in decision making.
I've noticed this "Gummy" with other brands also (Duralast).
Loose Screw is offline   Reply With Quote
Old 03-03-2025, 12:59 PM   #2
1970cstblazer
1970cstblazer's Avatar
Exclamation Re: Important! GATES Rubber Fuel Line! Read!
wow, their "fuel" hose is not resistant to fuel..
Good to know!
1970cstblazer is online now   Reply With Quote
Old 03-03-2025, 02:19 PM   #3
72c20customcamper
72c20customcamper's Avatar
The outer cover shouldn’t get any fuel on it in normal conditions . My experience is that the lines get mushy also when exposed to oil or any hydro oils. That’s why it’s not rated for transmission cooler line use
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 03-03-2025, 02:54 PM   #4
MJN
MJN's Avatar
Looks like Gates makes submersible fuel hose that the outer covering can handle contact with fuels
https://www.gates.com/us/en/fluid-po...00-000012.html
Part of the description for their submersible hose ' Most fuel lines are only designed to handle fuel on the interior of the hose, which can be damaged if the exterior is exposed to fuel.'
Their fuel injection hose, https://www.gates.com/us/en/fluid-po...00-000003.html
Doesn't say anything about the outer cover resisting fuel/gasoline/ethanol ' Oil, heat, ozone, and abrasion-resistant cover.'
Looks like the outer cover isn't made to be exposed to fuel but the inner tube is. Similar wording on Dayco's website for their hoses as well,https://www.daycoaftermarket.com/en/...njection-hose/, so I have doubts Gates hose is the only one this happens to.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 03-03-2025, 03:23 PM   #5
70STOVEBOLT
70STOVEBOLT's Avatar
I have been using Weatherhead General Purpose H10106 3/8 hose for gas for a long time, and it does not get gummy on the outside.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 03-03-2025, 05:21 PM   #6
Rickysnickers
Rickysnickers's Avatar
I don't know if this stuff is submersible or not, but I have it on my truck and have had no issues. https://www.russellperformance.com/s...2niXV_n4mmnKHF
Old 03-04-2025, 11:21 AM   #7
SCOTI
SCOTI's Avatar
The Gates submersible hose works but be prepared for the cost.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 03-04-2025, 12:49 PM   #8
Willshook
Why is this important?
Willshook is offline   Reply With Quote
Old 03-04-2025, 02:36 PM   #9
SCOTI
SCOTI's Avatar
Wrong fuel line material = failure (depending on the application).
Failures can be simple or severe in nature so using the right (& best) type of rubber fuel hose for the application is a smart thing.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-04-2025, 02:56 PM   #10
Willshook
This isn’t the wrong application.
Old 03-04-2025, 03:01 PM   #11
SCOTI
SCOTI's Avatar
Never said it was.
My response was toward the info member MJN posted. The submersible stuff works inside the tank as well as outside. It's also a lot pricier vs standard & fuel-injection rated fuel hose.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-04-2025, 03:08 PM   #12
Willshook
Never said it was.
You quoted me on your response, so I'm confused.
I don't understand why Gates, who is a top quality provider, fuel hose being sticky on the outside when exposed to fuel is important - which is what the post is titled.
I assume the outside covering is made to self-heal from nicks and cuts from road debris, which is why it's soft. I doubt it's some sort of quality issue.
Maybe a better question for Gates is WHY is it sticky on the outside...
Old 03-04-2025, 03:35 PM   #13
SCOTI
SCOTI's Avatar
Standard forum misunderstanding.
Old 03-04-2025, 10:42 PM   #14
dmjlambert
dmjlambert's Avatar
Well it's important if you have some Gates fuel hose on hand that you cut pieces off to install on the truck, and you go and try to use a nice long section of the hose to siphon from one container to another and instantly ruin the hose and you get a huge mess of difficult-to-clean black sticky mess all over the place including on clothing and hands and gas containers. I was pretty mad about that. There are no quality car or truck parts of any kind that go anywhere on the vehicle that instantly melt and make a huge mess just because it got some gas on it. There's plenty of poor quality and improperly engineered parts out there and this is one of them, that is my assessment.
Last edited by dmjlambert; 03-04-2025 at 10:50 PM. Reason: add information and spelling and grammar improvement, I hope
dmjlambert is offline   Reply With Quote
Old 03-05-2025, 08:25 AM   #15
Joyridin
Agreed. I have spilled gas on my radiator hoses and they don't melt. Why would you sell a product that is intended for gasoline and have it disintegrate when it comes in contact with that fluid regardless of whether it is inside or outside? If the intended purpose of that coating is just to make the hoses look black and pretty, please....I can make it look nice myself.
Joyridin is offline   Reply With Quote
Old 03-05-2025, 04:56 PM   #16
Willshook
I use hundreds of feet of that stuff in a year with no issues. I understand the concern, but labeling it as a quality issue without understanding why it's the way it is I disagree with. I've reached out to Gates about it, but as I noted I suspect it's simply that the outer layer is road debris protection.
Use what you like, of course
Old 03-05-2025, 05:08 PM   #17
70STOVEBOLT
Even trusted names/companies have product quality issues sometimes. I doubt Gates would want this to happen. I would be interested in hearing their response.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 03-05-2025, 05:20 PM   #18
Willshook
It doesn't appear to be a quality issue as they've acknowledged it happens, so it appears to be by design. The question is why.
I'll share whatever I get back.
I'm just trying not to jump to conclusions but to research the problem.
Old 03-05-2025, 05:25 PM   #19
chappys4life
I switched to earls vapor guard. Being in texas have to prepare the rides for a brutal summer. Vapor lock and cooling systems have become my biggest 2 things to fix
chappys4life is offline   Reply With Quote
Old 03-06-2025, 02:26 AM   #20
jhe.1973
jhe.1973's Avatar
WOW!!!
Big thanks to the OP for starting this thread and for the discussion.
I've been wrenching for over 60 years and never ran into the situation of the outside of the hose getting sticky from fuel.
But it makes me wonder about this situation I experienced a couple of years ago:
I came to start the truck after one of its few months of slumber and found the fuel line from the filter to the carb was swollen, soft, mushy, sticky and, as you can see, just draped over the radiator hose.
The line to the filter was fine and I was pretty sure I had cut them from the same stock.
I had written it off as to the 'new improved' fuel that is sold these days - but now I'm not as sure.....................
Best wishes to ya’ll. Sincerely, Jim
"To invent you need a good imagination and a pile of junk" - Thomas Edison
"I've always wanted to get a job as a procrastinator - but, I keep putting off looking for one - I guess I'll never realize my life's dream - so sad." - Me
My C30 wrecker build/repair/update thread: https://67-72chevytrucks.com/vboard/...d.php?t=855904
jhe.1973 is offline   Reply With Quote
Old 04-15-2025, 08:58 PM   #21
Loose Screw
Yeah, guys that put time into builds, like over at H.A.M.B. ALL say using Rubber line is a "Hack"! Maybe they're using AN where they need flex. I need to check to see if they've talked about this over at Bob Is The Oil Guy's, there's a bunch of pocket protector guys over there.
I will change out that New gooey line when I got time someday no matter what anyway.
In the meantime I hope my carb don't get gummed up and I'll make sure my fire extinguisher is charged up!
Old 04-16-2025, 11:07 AM   #22
kaycee
kaycee's Avatar
CUT a piece of the gummy line off and slit it open and see if its gummy on the inside
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 04-16-2025, 01:30 PM   #23
Loose Screw
Oh, I will when I eventually get down to getting it all out of there. There's pictures on H.A.M.B Jalopy Journal's website fyi...
But Really, How can Companies like Gates and Duralast justify selling this cra...stuff even if it deteriorates from the exterior like this? Seems Pretty Hazardous!
Old 04-16-2025, 02:37 PM   #24
sixty8HDC30
This seems like one of those scenarios where back in the day I'm betting all GATES fuel line was the "submersible" type. Now they have found ways to cut costs with modern manufacturing and engineering and probably many good lawyers, to be able to sell a variety of fuel lines for various applications instead of a single quality fuel line that can be used over many different applications.
Once upon a time, fuel line was fuel was fuel line. Now its fuel line is fuel line but you better read the fine print.
This is not a quality "problem" this is by design.
sixty8HDC30 is offline   Reply With Quote
