Old 01-16-2004, 12:55 AM   #1
bluec10
bluec10's Avatar
Swap TH350 for 700R4
Someone has got to have done this...
The TH350 in my '76 is getting pretty tired. It's leaking from the back end and there's a bit of slippage in reverse.
I could pick up a TH350 pretty easily, but I was wondering how easy it would be to swap in a late 80's TH700R4. Has anyone done this? Will it require a new driveshaft? Different linkages and cables?
Present:
2015 Tacoma. Yeah, not a GM, but I love it.
1969 GMC 32,000 - fix, drive, relax, fix...
2019 BMW R1250 GSA - Yahoooooooo
1979 Honda GL 1000 - retro touring at its best.
Past:
'05 Sierra 4x4 - Had 270,000 KM and running well when it was written-off by a stop sign runner.
'94 F-150 from the "F word" company. I'll admit it...good truck. Sold what was left of it for $800 to a guy who came to pick it up at 11:00 PM with cash in hand. Hmm.
'79 Sierra Grande (Black) organ donor - perfect rebuildable 4-bolt 350 and a good TH350.
'76 Sierra Grande (Orange) - hate isn't too strong a word. Kid who bought it turned it into a hot rod.
'68 C-10 R.I.P. - Dad's old truck...too far gone to resurrect.
'59 C-50 - with hoist. Truck is gone, wife isn't. Nuff said.
bluec10 is offline   Reply With Quote
Old 01-16-2004, 01:05 AM   #2
bigblock73
yeller
bigblock73's Avatar
I did this swap. But I am not finished (in the middle of a body off resto), but can tell you what I know.
You will have to slide back the trans x-member and drill new holes to mount it. You will also need to modify your carb in order to run the TV cable required for this trans. Bowtie Overdrives has an excellent site with tons of information, might want to swing by there.
The trans cable should be fine, and I believe the driveshaft should swap out as well. You will need to calibrate your speedo with the appropriate trans gear as well.
That is a quick rundown, maybe others will chime in as well.
bigblock73 is offline   Reply With Quote
Old 01-16-2004, 03:24 AM   #3
Opper77
Ob-Gyn Kenobi
Opper77's Avatar
driveshaft will need to be shortened, the x-member will move, most (?) 700r4 have electronic lockup converters I think so you'll need a module or something to control that if you want that feature(unless you have a th350c already) , maybe a new flexplate depending on your bolting arrangement, speedo gear I think only changes with rear end gears, but I could be wrong there....I haven't got to that point on mine yet either....
I'm going from a 700r4 to a th400 so I'm backwards from you, but I think mostly the same things change
'85 GMC Shortbox...
I used to have a firm handle on life....then it broke off.
Opper77 is offline   Reply With Quote
Old 01-16-2004, 09:56 AM   #4
maineiac
It depends upon if you have a short shaft 350 or long. I just went back to a 350 when my 700r4 went to lunch but my drive shaft was not cut the only mods that had been done was to move the cross member back and use the holes that were the back for the front and drill 2 new for the back. The 700r4 is actually just an inch or two shorter than the long shaft 350 so the drive shaft will be okay if you have a long shaft not sure if you have a short shaft if you might have to cut it or get one from a junk yard. Lots of people here have done it I am one of the few that went back to originall just too many ponies for the early model 700r4. If you go to www.73-87.com and check out the info there.
Steve
maineiac is offline   Reply With Quote
Old 01-16-2004, 02:19 PM   #5
bluec10
bluec10's Avatar
Thanks for great info guys - the links look very helpful.
Present:
Past:
Old 01-16-2004, 03:43 PM   #6
mcmlxix
Collector of Projects
mcmlxix's Avatar
What is the length of the drive shaft from center of U-joint to center of U-joint on a short bed with a stock TH350/v8 combo?
Rich
1972 K5 Blazer CST Click HERE
