Old 03-04-2025, 05:53 PM   #1
unclebrad
unclebrad's Avatar
Steering Column Support Bracket?
My steering column was shortened a while back, and the guy that did the job welded a plate between it and the firewall for support, since the old steering box that provided support at the lower end was removed. His craftsmanship left much to be desired.
I recently needed to take the column out and removed that plate.
Now, I am putting the column back in and need support at the firewall. I do not want to use the plate that I took off. And the plate that is made to make a seal as the column passes through the firewall is not going to do the trick.)
Does anyone sell a bracket of some sort, to support the steering column at the firewall?
55 Cameo w/ 409/700r4
unclebrad is offline   Reply With Quote
