Old 03-09-2025, 03:46 PM   #1
Rg500gamma
Restore 72 OUTER ALUMINUM grill help
I have a few dings in the upper corner of the outer grill.
I am aware that it was clear anodized from the factory.
$300. + for a new one, I can't justify. I attempt with small jewelers type of ding hammer to tap back in shape.
Anyone do this ? Your anodizing removal method and did you send out to get new anodizing or use a rattle can clear after ding removal
Rg500gamma is offline   Reply With Quote
Old 03-09-2025, 07:43 PM   #2
custom10nut
custom10nut's Avatar
Re: Restore 72 OUTER ALUMINUM grill help
If you’re refinishing the WHOLE grille shell, use either Aircraft Stripper, or Old School Oven Cleaner.
Be careful with either of these and it’s best to use them outside, for maximum ventilation.
When you’re done with the polishing, use Ever-Coat to protect it.
There’s a very detailed Thread on polishing the Grille Shell and Side Mouldings, just find it in the Search bar.
custom10nut is offline   Reply With Quote
Old 03-13-2025, 10:42 AM   #3
68 C10 Driver
Just be very careful, products like Easy-Off will eat aluminum if you leave it on too long
68 C10 Driver is offline   Reply With Quote
