Old Yesterday, 08:55 AM   #1
IT Cowboy
IT Cowboy's Avatar
Location: Clarkdale, Arizona in a van down by the river
My rear slider had chrome trim around it - installation?
I have a rear sliding window and I guess it had chrome trim around it as part of the deluxe package. How does this chrome trim install, is it after putting in the window and does it wedge between the rubber and glass?
1972 C10 Custom Deluxe Highlander 402
2019 Toyota Tundra SR5
2018 Jeep Wrangler Sport
Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility.
IT Cowboy is offline   Reply With Quote
Old Yesterday, 11:07 AM   #2
PbFut
Re: My rear slider had chrome trim around it - installation?
Gasket goes on window first, then trim on the gaskt, then assembly roped into the opening. Use lots of lube.
Edited order. Need to wake up
PbFut is offline   Reply With Quote
Old Yesterday, 03:22 PM   #3
Richard
Actually, what I have experienced is the the rear stainless trim was deleted when a slider was ordered and installed. My truck is a Custom Deluxe has a factory slider but no rear trim. I am going to add it back. Reason it is deleted I do not know. Pretty sure others will confirm what I have found.
Richard
Old Yesterday, 03:43 PM   #4
IT Cowboy
IT Cowboy's Avatar
You are going to add it back or not. So I understand that the rear chrome trim was removed when a sliding rear window was ordered?
Edit: in doing a little research, I think you are right here is what I found
Yes, when a sliding rear window was ordered on a 1972 Chevy C10, the factory-installed chrome trim (Deluxe Trim) around the rear window was deleted. The sliding rear window came with its own black rubber gasket that did not accommodate the stainless trim used on the fixed rear window.
If your truck originally had a Deluxe Trim Package, ordering the sliding rear window would mean the rear window trim was omitted, but the rest of the exterior trim (such as the windshield trim, side moldings, and drip rail moldings) remained.
This is like being a detective, I wish I could go back in time and see exactly how my truck came off the assembly line. I was prepared for the PITA job of removing the rear window and trying to add the chrome trim.
Old Yesterday, 05:20 PM   #5
loudchevy
loudchevy's Avatar
Cowboy,
Did your research say only the 72 was like this?
My 70 had a rear slider with SS trim. I'm not sure if it was factory as the SPID sticker was completely faded on the glove box door. My old front windshield also had the trim so I assumed the truck had the option.
I opted to go with just a single piece of glass and a standard gasket for my build. They seem like they would be a pain in the butt to install. I still have the trim in the shed. Pretty sure the leaky slider was the cause of the rust I had to repair on the bottom of the window opening.
Scott
1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
