Old 03-15-2025, 09:16 PM   #1
BanjoDude
DIY Powder Coating
If you haven't checked out the DIY powder coating options out there, you really should. All you need is a powder gun and a toaster oven, and you can make something brand new in under an hour. Did this brake booster bracket for the '69 C-20 today - pulled it, sandblasted it, powder coated it, reassembled it, and it's ready for reinstallation - in an hour. Happy to answer questions if you have any. I was intimidated at first, but it is super easy to learn.
Found Grandpa's old '69 Chevy C-20 - It'll never leave the family again.
"For just a little more, you can do it yourself!"
BanjoDude is offline   Reply With Quote
Old 03-15-2025, 10:39 PM   #2
Rick Bollinger
Re: DIY Powder Coating
I agree, I bought the Eastwood system and love it. Picked up an old electric stove for $50 and toaster oven for $7. I bead blast with the harbor freight booth with the vacuum system. The hardest part is dry air. I use 3 water separators in a row and does a pretty good job. Most powder coat shops will sell powder for a couple dollars a pound especially if they do your larger parts. I did all my e-brake handle, cover, ac and alt brackets and a ton of bolts.
Rick Bollinger is offline   Reply With Quote
Old 03-16-2025, 12:58 AM   #3
lil hoodlum
lil hoodlum's Avatar
Thanks for sharing. I have used a commercial powder coating company in the town I live in.
Would be handy to be able to do small parts on my own.
1968 C10 327, 3 speed manual, LWB stock height daily driver.
1968 C20 327, 4 speed manual, LWB stock height custom camper with heavy duty leaf springs rear, 50th anniversary edition. Hoping to press into daily drive status soon.
lil hoodlum is offline   Reply With Quote
Old 03-16-2025, 02:45 AM   #4
Rust_never_sleeps
Rust_never_sleeps's Avatar
does this require media blasting, or just clean and dry?
1970 C10 Custom longbed 350/350
“Carburetors are forgiving, timing is not” — Thunderhead289
Rust_never_sleeps is online now   Reply With Quote
Old 03-16-2025, 08:18 AM   #5
Joyridin
I have done many car parts including brake calipers, bolts, brackets etc. I use a toaster oven I bought at Walmart for $25 years ago.
If you can find an old electric kitchen stove and have room, you can do brake rotors, spindles, and many other larger parts.
Joyridin is offline   Reply With Quote
Old 03-16-2025, 11:03 AM   #6
RichardJ
There is almost zero market for used kitchen ovens. Check the FREE section of craigslist or other local listing and it won't take long before you find someone doing a kitchen remodel. Attempting to make a couple of bucks off of old appliances is more of a distraction than any $ savings. It may take a few calls to separate the gas from the electric ovens, because for some reason, most of the listings don't specify.
Harbor Freight has only Black and White powder. I've used their black on several items and worked well. Eastwood has a large selection of colors and work well for a DIY like me.
Eastwood also sells a Zinc Plating kit that works for small nuts and bolts.
I restored this old '20s Emerson table fan some years ago using both eastwood products. It isn't chrome, but I think very presentable for many uses.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 03-16-2025, 07:19 PM   #7
BanjoDude
Media blasting helps with adhesion, but as long as the part is clean and free of any grease, powder sticks just fine. I just put bolts on a wire wheel to clean them up and powder coat the heads, and I've never had a problem with adhesion.
Old 03-16-2025, 09:40 PM   #8
Rick Bollinger
I media blast most things and then use brake cleaner or acetone to make sure everything is clean. And again if there is a powder coater near you get your powder from them. Last time, they charged me like 2-3 dollars for a couple of pounds. They also have lots of colors. I think Eastwood is around $20 a pound.
Old 03-19-2025, 06:14 AM   #9
jjzepplin
jjzepplin's Avatar
This would be awesome. I have a blast cabinet. Just need a stove?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
