Upper Control Arm Mounts C10 vs C20
Pretty simple question, tried searching with no luck, so apoligies upfront.
Are the upper control arm mounts on a C20 the same as those on a C10. I guess specifucally I am asking about the mounting studs that the crossshafts mount to. Are they the same size/dia/bolt size. Looking to see if C10 upper arms will bolt directly up to a C20 chassis. |
#2 | |
Re: Upper Control Arm Mounts C10 vs C20
| Bookmarks |
