68 k10 engine crossmember question
Hello, I'm getting ready to drop in my new crate early 90's 350 tbi/700r4/241c passenger drop combo in my 68 K10, and I'm leaning towards moving the engine crossmember forward from the current 6 cylinder factory position, to get more firewall clearance, and move the fan closer to the radiator. If I leave it as is, according to my measurements of the engine, there's about 4-5" between the fan and the radiator, even with my long shaft water pump. If I move it forward however, the crossmember will be more or less directly over the axle. That seems like it would be a problem. Is it? Am I overthinking it? Did the factory install v8's in the forward position or the rear?
Thanks- |
All about them K’s
![]() Join Date: Jun 2014
Re: 68 k10 engine crossmember question
All K V8 trucks came with the engine in the rear position and use a deeper shroud to make up the difference between the fan and radiator.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
| Bookmarks |
