![]() Join Date: Jul 2015
Clean looking Heat Only Option
I'd like to keep the underhood area clean and uncluttered looking on my truck build. I like the look of just few hoses passing through to an under-dash unit like Restomod Air or Vintage Air, but don't know if A/C is in my future with the truck.
Does anyone make a heat only option that works with our trucks? I guess I could always buy and install an option with A/C, and then it's there if I ever wanted it, but also trying to control costs.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
Re: Clean looking Heat Only Option
You could look into heavy equipment heaters or a vintage car heater. I can't see why you would want to go that route as you lose the the advantages of heating outside air and are stuck with recycling the air in the cab.
https://www.amazon.com/dp/B09CPQLMH1...T1zcF9kZXRhaWw https://www.coldmasterinc.com/under-...versal-heaters https://www.hotrod.com/how-to/1006sr...r-restoration/
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
Speedway Motors has street rod heaters that mount under the dash. Heat and defrost along with ducting options.
I think both VA and Old Air have heater only solutions. That said, I'd suggest purchasing the under dash evaporator/heater core unit and plumb it for heat only. Leave the evaporator capped off until/if you or some other person decides to purchase and add the A/C components to make that work. You probably would want to purchase the control panel that would run the A/C in the future and install it even though no A/C. You'd need the under dash unit, ducting, vents (if no-A/C cab), controller, a bulkhead for firewall to get heater hoses into the cab and a heater shutoff valve. No need for the compressor, condenser, receiver/dryer or the plumbing for those things. Just cap off the firewall bulkhead ports for A/C lines. Doing it this way, you can still throw air at yourself with the blower fan when it's warm out but it will be ambient temp air. No idea what that would cost but Ima guess just a few hundred more than a heat-only solution. Beware, first hot day you find yourself driving it after you do this, you're likely to start ordering parts ![]() EDIT: Vintage Air: evaporator kit: 1340 (don't think they have heat only) ......Old Air: evaporator kit: 1195 - 1895 (lots of options) ......Old Air: heater only: 525 cable operated +100 for digital ......Old Air: generic heater only: around 200 Hth, -Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold Last edited by weq92f; 03-31-2025 at 06:48 PM. Reason: adding colour |
![]() Join Date: Feb 2022
If it is a AC truck, the heater core is inside. This would allow you to shave the engine side of the firewall pretty clean and still maintain heat function for now and AC ability in future if so desired by you or future owner. I agree, driving these trucks without AC in mid summer is not very comfortable. 50 years ago, we were not so accustomed to conditioned air.
E bay has a few heat / defrost units available with good prices..
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
![]() Join Date: Jul 2007
The old air unit is a bit spendy for a "universal" heat only unit.
The Vintage air units run a little over 300 now but have been popular with hot rod guys who want heat but not AC for years. Small but efficient. Most states require that you have working defrosters even if you don't have heat.
Thanks for the links and detailed suggestions, guys! The truck won't be going anywhere, it was my grandfather's truck and what I learned to drive on. A/C would be nice to have, one day, so going that route probably makes the most sense.
It is not a factory AC truck.
| Bookmarks |
