Old 01-16-2004, 01:44 PM   #1
MeannGrumpy
70 3/4 front hub and drum assembly
Need to know a description of parts assembly for the wheel bearing assembly and parts as they go into place. Mine does not have a locking ring between the nuts and I think it should( part numberif possible) and how much end play there should be in the axle shaft,mine seems to move in and out a lot.
1970 Longhorn, factory air & Cruise,Tach vac
1970 C 20 3/4 4x4 350 with turbo 350 auto,
MeannGrumpy is offline   Reply With Quote
Old 01-16-2004, 03:28 PM   #2
FOOTHILLGUY
the part # is a dana spicer kit 28068x it is usually stocked anywhere dana spicer is sold. the axle will move in and out alot about 3/8 inch for when it turns left to right it can move around and not pull the axle out of the carrier
later
virgil
FOOTHILLGUY is offline   Reply With Quote
Old 01-16-2004, 05:06 PM   #3
MeannGrumpy
Front hub assembly
Thanks FoothillsGuy; couldn't find any info here about my 70 4x4 the GM places here say its too old and they have no longer got the parts books. One place had but that page was missing, just my luck. Wheel bearing torque settings?
Old 01-16-2004, 08:16 PM   #4
1969 GMC
1969 GMC's Avatar
the 1970 dana 44 you have there is a one year only unit; it has open knuckles and drum brakes. every year prior had closed knuckles and drums, and every year after had open knuckles and discs. have you considered doing an axle swap to get front discs?
I know its on my list.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 01-16-2004, 11:29 PM   #5
MeannGrumpy
Drum Brakes
I am getting along fine with the old drums and they were new not to long ago so I think I'll just keep them for now.
Old 01-17-2004, 06:09 PM   #6
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Mr. grumpy, what rear end do you have and what gears did your 4wd come with? I'm looking at another c20 4wd w/ 4.10s. Thanks,
I hear you on the drums, mine are doing fine also. If you ever need front wheel cyclinders goto napa and get the ones for a 69 3/4 ton.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 01-17-2004, 09:17 PM   #7
MeannGrumpy
Gear ratios
Mine adds up to a 4.10, got to put new crown bearings in, whole lot of fun there! If you come across a blue center cap in half decent shape please send my way.
