![]() ![]() Join Date: Feb 2009
Question(s) about cast iron cores for water/coolant
I had this blasted with some things. It might be the original housing off my 71 402, not sure. Could have been new to the truck in Feb. 1993 to be exact, when the engine was rebuilt.
I'd like to replace the clone smooth surface housing with this cast iron piece. Think I'll paint it with por15 engine orange, and a sponge brush - works well on cast iron, especially small stuff. Got me wondering about core finishes, the interior surface was pretty corroded before it was blasted. Let me guess, the factory "sprayed" the interiors with the top coat, or something else not expected to last....I really don't know, perhaps they figure corrosion protection in coolants good enough - not sure, so I'm asking. That, and how would you finish the interior, if anything? With a green observation, seems cast iron holds up up well to water, hot even better. Perhaps cores were hit with something temporary, for rust prevention during storage, hmm.
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too. Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc. The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
Re: Question(s) about cast iron cores for water/coolant
Corrosion happens when the antifreeze is old. The corrosion inhibitors are used up over time .
![]() Join Date: Dec 2009
I use this on the inside of tractor cases that I have restored.
https://www.amazon.com/Glyptal-Brush...30737255&psc=1 I don't know if it is Anti-freeze resistant ,But I bet it is. What do you think?
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 85 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
![]() Join Date: Jun 2005
The cast iron water neck would have been stock on the 402. If you are worried about the inner surface, you should think about the block as well. Personally, I think if the coolant is kept up to snuff, the corrosion inhibitors will do the job, nothing else needed.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
Ram-A-Lam-A-Ding-Dong
![]() Join Date: Jan 2013
^ Yup.
#6 | |||
I can't see where it's heat resistant, but doesn't mean it's not.Quote:
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too. Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc. The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 04-08-2025 at 06:59 PM. |
| Bookmarks |
