Best disks that fit under the OEM 15 Rally ?
Hi guys, Im about to place an order for the CPP front disk brake kit (drop spindles, rotors, calipers)
Before I do, Id like to check if theres anything else out there with improved braking performance that will fit under the 15 truck rally? Anything out there I should consider before placing the CPP order? Thanks
1969 C10 Shortbed |
![]() Join Date: Jun 2005
Re: Best disks that fit under the OEM 15 Rally ?
12" rotor is about as big as will fit. You could get drilled/slotted for better cooling if you need it.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
What about calipers?
1969 C10 Shortbed |
Ram-A-Lam-A-Ding-Dong
![]() Join Date: Jan 2013
Don't know about with dropped spindles, but single-piston calipers will fit. Multi-piston calipers can interfere with stock wheels.
Nothing wrong w/the OE standard single piston calipers from the 73-87 trucks.
'Dual piston' calipers that fit within the confines of a stock 15" barrel are not going to offer much benefit. There would be a slight increase of the contact area for the pad but it would be minimal vs the cost vs the stock D52 caliper/pad. Wilwood makes a 'replacement' D52 caliper if you want the bling but again cost vs. functional output is a wash. As far as drilled & slotted rotors? They're lust a look @ me thing so the 15" wheels used would need to have a large enough 'window' area to see through. The D/S rotors will actually have reduced surface contact area (which helps braking) vs a stock/solid surface rotor; can't be serviced (turned down), + are known to form stress cracks. A good set of brake pads, flex lines, proper master cylinder, properly adjusted rear brakes, & an adjustable valve plumbed inline to the rears to help dial in bias if necessary is a solid brake package. The OE type set-up also has the benefit of easier to source parts when on the road if something were to need repair.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 04-08-2025 at 05:16 PM. |
#6 | |
I put D/S rotors on my DD once years ago: 5 series sport. Will not do it again. Be aware that during the rotor seasoning and pad break-in, these things make a very odd sound which was quite concerning at first for me. Not to worry, sound diminishes quickly. I got the stress cracks near end of pad life and these rotors I purchased were a higher end brand. -Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
I couldn't recommend drilled or slotted rotors... you just lose braking surface area. The braking system on these trucks remains largely unchanged from 71-96. I daily drive a 72 long bed with truck rallies and drop spindles in a densely populated area, and braking has never once made me nervous in modern traffic or left me wanting "more" stopping power. That said, its a relatively stock truck. If I increase power, i might look at some different brake options.
Side note: I originally had 2 inch CPP drop springs with the spindles and the truck could not be aligned and chewed tires fast. Some guys say these trucks can be aligned with 2 inch springs but not without longer A arms in my case. I decided to use Moog brand stock length springs on this build and the ride difference was immediately noticeable. I don't know what the spring rates are, but the CPP coils were softer and the CPP shocks didn't feel quality at all. |
| Bookmarks |
