Steering gearbox loud Click
Hi all, 1969 C10
Installed a re-manufactured gearbox (all new tie rods, ball joints etc). Using CPP 2.5” drop spindles/ disc brakes. Just installed the column & half shaft, oil added to the pump. Not running the engine yet. Turning left, no issues (about 2 turns) Turning right, there is a loud click at about 1turn (wheel feels like something is binding but will turn). Noise seems to be from the gearbox. I have not run the gearbox with pump pressure yet. Thank you!
69 396BB Turbo 400 Fleetside, 3:07 Gears 2.5" & 4" drop 2020 Silverado 2500LT 2006 Subaru Forester 2019 Chevy Cruze Last edited by 69BB396; 04-10-2025 at 03:33 PM. Reason: Added info |
![]() Join Date: Feb 2022
Re: Steering gearbox loud Click
You can prime and run the pump with a socket, and drill. Make sure you spin it the correct direction. Things may settle into place with fluid pressure.
#3 | |
Pump is all bolted up, belt etc on. I’m finishing up the wiring, then I can start er up for pressure. Thanks!
69 396BB Turbo 400 Fleetside, 3:07 Gears 2.5" & 4" drop 2020 Silverado 2500LT 2006 Subaru Forester 2019 Chevy Cruze |
Still a good idea if you have room. One less leak point to deal with on start up. Especially if you added hydro boost. I really struggled to get the AN adapters to seat. The amount of needed torque was way high to finally seal. I actually took the position of, it going to strip the threads on the pump or seal. Thankfully it sealed.
Ram-A-Lam-A-Ding-Dong
![]() Join Date: Jan 2013
I've never understood the utility of the AN flare. Yes, I know that they are used on aircraft and spacecraft, so maybe it's just a production time-saving choice? Though when I worked on spacecraft, it was at best one every few years, and single- or double- flare time couldn't have possibly figured into it. I think that they are used on spacecraft only because they were developed and worked on by people who developed and worked on aircraft.
#6 | |
Had to spin it fairly fast until it finally primed. Had the wife at the wheel turning lock to lock. Dang click is still there. Discovered a leak too. I have two 45’s and a self-made pressure hose, I’m a bit paranoid lol. Had to use some muscle on those fittings, leak stopped for now. But that click.
#7 | |
| Bookmarks |
