Old 01-16-2004, 03:31 PM   #1
mrein3
mrein3's Avatar
Big Block in a 4x4
I MIGHT be able to get my hands on a complete 454 for my truck. My 350 is tired so I have to do something one of these days. My engine rebuilder friend said for what I use my truck for I have two choices: 383 or 454. He said everything else is pretty much a waste of his and my time.
Given those parameters (383 or 454) I know some of you guys wedged a big block in your 4x4. I don't necessarily have to keep it stock but if I went with a 383 I could simply put that engine in in place of my 350 and use all stock components. If I go big block the General never made a 4x4 with a big block until after 1972. What kind of problems will I run into if I go down the big block path?
Do stock (from 2wd) exhaust manifolds work/fit?
Do stock (from 2wd) engine stands work/fit?
I know a lot of you guys have done this swap. What did you do?
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
