Old 04-12-2025, 10:21 AM   #1
KyleSeal
KyleSeal's Avatar
Pinion Angle for Slammed Trucks
Im currently laying frame with a Porterbuilt front end and a DIY rear (step notch, factory arms, watts link) and am curious on pinion angle setup.
I have carte blanche when it comes to setting the transmission tail shaft height / angle, and am using a 2-piece driveshaft with the semi solid carrier bearing.
This is also with the CPP trailing arm crossmember.
What would the ideal transmission tailshaft angle be, along with the rear differential at ride height? I can adjust the rear with shims so if need be I will.
C10 Club Virginia President
Toano VA
"Sometimes I do serve as a good bad example. Glad to be of service."
My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809
KyleSeal is offline   Reply With Quote
Old 04-12-2025, 10:42 AM   #2
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: Pinion Angle for Slammed Trucks
Close to zero as possible.
And a slip yoke like this will decrease the rear shaft angles compared to a gm truck slip
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 04-12-2025, 11:14 AM   #3
KyleSeal
KyleSeal's Avatar
Close to zero at the tail shaft of the trans? Or the diff?
Toano VA
Old 04-12-2025, 11:34 AM   #4
KQQL IT
At the body shop.
KQQL IT's Avatar
Tailshaft, the pinion agle will depend on your end ride height.
Old 04-12-2025, 03:16 PM   #5
HO455
HO455's Avatar
There is an ideal angle when setting up a static system but vehicles are always a compromise due to changing locations of components in relation to each other i.e suspension movements. Add in different service applications and the numbers can be quite different
Is it a long bed truck?
What engine/transmission combination are you running?
You say "carte blanche" does that mean raising the transmission tunnel?
Are you locked in to using a 2 piece driveline?
I recommend having this conversation with the folks at Porterbuilt. They have experience with these trucks and will know the limitations your likely to run up against.
Here is a good calculator to help you and I recommend watching the video. Both for know the correct method to measure the angles and the vocabulary knowledge to make for clarity in conversation.
https://spicerparts.com/calculators/...gle-calculator
RIP Bob Parks.
Old 05-09-2025, 07:13 PM   #6
connorm
connorm's Avatar
From what I have read, make sure that your engine/transmission bushings are all in good shape then adjust your driveshaft to that. The visual that I have attached shows how they should be in relation to each other. Although if you look more into offroad driveshaft angles they talk about some more extreme pinion angle differences through the travel of the suspension. With factory trailing arms and the CPP crossmember that should help you with the angle change through the suspension travel.
1970 C/2500 Ol' Green https://67-72chevytrucks.com/vboard/...d.php?t=668003
2016 GMC Sierra K1500
1953 Mercury 2 Door Sedan https://67-72chevytrucks.com/vboard/...17#post9381817
connorm is offline   Reply With Quote
driveshaft, frame laying, pinion angle, porterbuilt
